BMW 323i M50 2.5
rob0r
BMW 323i M50 2.5
Post by rob0r »
Yes... another one! Thanks to Retrobeemer for the hookup, I picked this up about 3 weeks ago. I've forgotten to take photos before I put it in the workshop, so have some rubbishy ones.
A mishap involving me assuming the brakes were seized lead to the car flying into the trailer winch when I temporarily moved it on the farm... Smashed valance and destroyed number plate! Luckily I'm getting rid of most of the valance and although the bumper wasn't touched that's being removed as well.
You may wonder why the bonnet's off, well that mess isn't hanging around in there for long! I despise K-Jet and the engine doesn't sound too perky
It needs full sills both sides, some welding to the rear wheel arch, inner front wing and chassis rails. Then it'll get an MOT and smoked around this summer with a welded diff.
rob0r
Post by rob0r »
Ah, found some pre smash pics!
murran
Post by murran »
has steveie wonder been doing some wiring mods under the bonnet? loving that relay kicking about near the battery! :lol: :shock:
DrGonzoPOW
Post by DrGonzoPOW »
Yeeeeeeeha!
Wakefield Hellfire
rob0r
Post by rob0r »
Tell me about it, the wiring bodgery doesn't stop there!
Wonder how much Laserchrom charged for fitting that? :shock:
--ALPINA--
Post by --ALPINA-- »
Looks like that relay is connected to the electric fan doesnt it?
j
rob0r
Post by rob0r »
I have the laserchrome reciepts, I can't remember off the top of my head but it wasn't cheap. The engine may need the tappets adjusting, or the head assembly is worn. What I don't get is that it's a 2.5 complete engine, they've taken off the far superior motronic and stapled on the K-jet. It's massively over fuelling the car and runs horribly. But this is being taken care of and the K jet is going in the bin.
Yeah the relay is for the fan. The rad is coming out anyway so it will be sorted properly. The ignition electics are bust and the car starts with a toggle switch and push button, you still need the key though for the steering... there are some interesting touches in this car for sure.
Just put an order in Beevers for some new sills. I've traded with my mate a rotten mini clubman if he sorts the sills!
Jason_323i
Post by Jason_323i »
Rob
I meant to Pm you as I have soem sills cheap if you can cancel your order
Jason
Z3M Coupe
2.8 Z3 Coupe
Caterham Supersport
op6
Post by op6 »
Are those seats original? If not and you are planning to ditch them I would be keen on the adaptor rails. Cheers
rob0r
Post by rob0r »
No, they've been made by welding on the E21 rails onto the new seat rails. IMO it's not been done very well and you really wouldn't want them! The seats are at all angles. They're getting removed as we speak, when the car's ready it will be getting recaros for the time being.
I've had E30 sport seats modified to fit in another E21, and it's really an easy process. Get the seats you want, cut off the seat mounts off the rails and weld them onto the E21 rails.
op6
Post by op6 »
I've had E30 sport seats modified to fit in another E21, and it's really an easy process. Get the seats you want, cut off the seat mounts off the rails and weld them onto the E21 rails.[/quote]
As usual a font of information and sound advice, what a cunning plan, much better than removing the plinths / scaffolding that the E21 seats bolt onto.
The result using your method doesn't leave the seat too high?
rob0r
Post by rob0r »
A little, but it's not unbearable. Look in my other thread about my M50 project, there's photos on the first couple of pages.
op6
Post by op6 »
Looked up your M50 project, saw the seats, but spent another hour reading the trials and tribulations of your project - fascinating, if only I had some of your knowledge and abilities. I am very impressed.
Cheers Don
rob0r
Post by rob0r »
op6 wrote:Looked up your M50 project, saw the seats, but spent another hour reading the trials and tribulations of your project - fascinating, if only I had some of your knowledge and abilities. I am very impressed.
Cheers Don
Thanks, although I don't think I deserve it! I removed the original engine two years ago and I've failed to complete three seperate engine swaps in the car! The black one is sitting tight now since I want an E21 done ASAP, so I'm concentrating on this grey one.
We should see some progress on this car sooner than later, tonight I'm firing up the grinder!
