Best you'll start a topic for your car in the 4 cilinder section. We like to read more from you about this e21 and its owner.
When you source a box, be sure to get one with a mechanical speedo cable output. That is at the rear end of the box, in the lower corner. Gearboxes for m10 without that cableslot are for e30 or e28. The'll fit, but you won't have a speedo signal.
Gearbox & driveline
Re: Gearbox & driveline
Thank you, I will post about the car in the 4 cylinder section.
Welcome Dan! More gearbox info on our regular website https://www.bmwe21.net/?page_id=124
