Pandemoniums 316 restore
Re: Pandemoniums 316 restore
Nice patchwork! :P
pandemonium001
My E21(s): E12 535i T (ish)
Post by pandemonium001 »
Jeroen wrote:Nice patchwork! :P
:loll think i might try the harlequin polo look.
with all the welding and grinding all i can smell when i come in the house is burning flesh, here is todays update:
welded up sill panel
a few dings to take out with my PDR kit
what i found on the front chassis leg
my very expensive mandrel, comonly known as engine crane leg 1
finished welding the back end up
a bit of high zink just for now
You sir, are a hero!
Those are some serious repairs you've done there. If it was me I'd have just sat and cried! :lol:
Your welding is so neat and tidy
pandemonium001
e21-Mark wrote:You sir, are a hero!
I do have moments when I just stand and stare for a good half hour, thinking :shock, then you just get on with it. :driving
nas80 wrote:Your welding is so neat and tidy
Thank you Sir.
pandemonium001
i will put this here for reference
this type of engine m42/44/clutch setup:
http://www.bimmerforums.co.uk/forum/f81 ... ad-t43562/
then bored, strocked, balanced for zippy revs and low psi boost.
problemchild75
Post by problemchild75 »
I do love these panda updates :boogie I'm very envious of your welding/fab skills
I have a 2 litre crank sat here if you want to stroke your m42?
pandemonium001
todays efforts,
found this when taking off some under seal, how botched repairs should always be investigated
here we go again.
pandemonium001
Looks like i need to upgrade photobucket, i have over 400 pictures of the e21 saved on there just now.
It has all been done with basic tools and i mean basic
4" grinder
1mm cut discs bosch
5mm grind discs dronco
ballpien hammer
£30 ebay panel hammers
cordless drill
spot weld drill bit
£30 of ebay panel clamps
185 amp mig never been above No2 setting
twist knot cup wheels
80 120 grit flappy discs
PPE
2 cans of upol hi zinc weld through primer
2 g clamps
£30 ebay sheet metal folder
drills
one luxury has been my sealy pnuematic joggler/spot weld punch, but cheaper manual versions can be bought
pandemonium001
can the Z3 2.7 steering rack be made to fit??
pic
Post by pic »
That's a pretty serious job you did! Respect to that! :thumbsup
pandemonium001
pic wrote:That's a pretty serious job you did! Respect to that! :thumbsup
Cheers, hopefully its the last of ones like that.
I have the origional BMW accident damage repair manual so it means i can check all my dimensions from suspension and subframe pick up points.
Taking today off for family time then get back at it next week.
Amazing update again!
pandemonium001
Jeroen wrote:Amazing update again!
Thanks
I will put this link here for my refrence again as well.
http://forums.bimmerforums.com/forum/sh ... Replica%29
