M20B20 to MegaSquirt build
garzon
My E21(s): 79 320/6 EURO
Re: M20B20 to MegaSquirt build
Post by garzon »
I was going to ask about the connector... Do you know any way to call that connector? Some hint I could use to find one.
Regarding the MAF, I found this one: SIEMENS 5WK9007 or 1730033, I think it is the same you have. Could you please confirm?
Thanks.
I use a 5WK9605 (BMW 13621432356) with a normal Bosch 3-pin connector.
Yep, thats the same one i'm using. Siemens 5WK9 007.
garzon
Post by garzon »
BertjeConti wrote: Sat Oct 01, 2022 3:57 pm Yep, thats the same one i'm using. Siemens 5WK9 007.
Thank you.
Wilmo wrote: Sat Oct 01, 2022 3:55 pm I use a 5WK9605 (BMW 13621432356) with a normal Bosch 3-pin connector.
do you know if it will provide the same readings than the Siemens 5WK9 007? Seems easier to find this one you used at USA -I am getting the sensors from USA since here at Colombia they are way to expensive-.
Thanks a lot.
garzon wrote: Sat Oct 01, 2022 4:06 pm
Thank you.
Thanks a lot.
Probably not, but you need to calibrate it to your own situation anyways. The flow characteristics are different from build to build, so finetuning is needed.
Here are a number of basic functions:
https://rusefi.com/forum/viewtopic.php?f=4&t=1726
I've used this connector for the 5Wk9 MAF, got them from the bmw dealer:
61131392224 p/n connector
61131376204 p/n terminal
Connector needed a little rework to fit, but doable.
Terminals from a old PC power supply do fit the terminal pins on the maf nicely, with these terminals and leads i did the first tests:
Connector and crimp terminals from the dealer:
Modified connector:
MAF and connector nicely installed:
garzon
Post by garzon »
BertjeConti wrote: Sat Oct 01, 2022 4:27 pm I've used this connector for the 5Wk9 MAF, got them from the bmw dealer:
Thanks a lot!! I just found it really cheap.
Wilmo wrote: Sat Oct 01, 2022 4:25 pm
Sir that's a great source of more information. Really appreciate it.
