m3gaz
My E21(s): looking
Post by m3gaz »
Blimey,am i the only one driving mine!
Today i put 30 quids worth in it and used it all up. :thumbsup :driving
P.S. i'm gonna wash it this afternoon.
Duracel79
Post by Duracel79 »
Well last night I swapped the wheels and tyres (in the rain) for the MOT that is now due.
And today ordered paint and fittings for the fibreglass panels.
Ben
Filled up and went for a B road blast round Surrey.
Sent my hard earned off in an envelope and booked a transporter via shiply website.
Just gonna finish my brew and then go give the fluids and tyres a check before I head off to Wales tomorrow.
drjim
Post by drjim »
At the weekend I removed all the empty boxes etc off the roof of the slug so I can actually see it in my garage. Popped the bootlid off and gazed adoringly at the fuel system. bonnet still has stuff piled on it!
Tomorrow I will finish the filler work on the rear arches and bonnet of the Baur then instruct my painting friend to go for it with the 2k high build primer prior to me doing much sanding. Depending how I feel, and if the ramp is cleared (has had a volvo sat on it having brakes fixed for last 2 weeks, but as the mechanic guy has left and the volvo belongs to Jason the "landlord's" son it's not moving in a hurry!) I might bolt the propshaft and gear linkage on. I might connect the battery up and see if the car is as alive as I hope - will involve some guesswork on the ignition leads. Must remember to tighten the rear hubs and stick split pins in, and fit the new track rod ends.
Tomorrow night I will assemble my (hopefully) last list of bits needed for the Baur and get them ordered from my friendly BMW dealer. I suspect I'll have to order a load of alternator/PAS pump bits as well as the rear light cluster gaskets, underbonnet foam pad, and the other thing I keep forgetting!
I will accept bets on how little of the above I actually get done!
1982 Saphirblau Baur 325i
Cars all gone!
DC
Post by DC »
this evening I connected launch control and fitted second rear sway bar - looking forward to test it on some racing track
Image <- 320i Turbo
Mcinek
My E21(s): '80 BMW 323i
Post by Mcinek »
DC wrote:launch control
More detail please mate
BMW "Freude am Fahren"
Marcin
DC
Post by DC »
I have Megasquirt ECU which has launch control as an option - it retards ignition and hold revs on user selected value before launch - this spools turbo and launch should be faster with good tires and non-slipping clutch :shake
Image <- 320i Turbo
Mine has Converse size 13 launch and traction control. ;)
Today I drove 150 miles across the Brecon Beacons to Snowdonia following the A470 for most of it, Great fun with plenty of 3rd gear overtaking, sweeping bends and not a speed-hump or pothole in sight. :thumbsup
:launch
today I cursed my dealer for ordering the wrong windowseals for my rearside windows for the second time. Besides that, I'm in the process of aquiring a LSD for my 323i. Besides that I made a bid on a 323i bodyshell. I want it, to chop of te roof an exchange is with my own roof, just for the original BMW sunroof. Hope my bid will be accepted.
murran
Post by murran »
today i drove to work. and drove home. topped up the coolant.
needs a wash, was guna do it after work but couldnt be arsed. it'll only get dirty again. sheffield roads are filthy!
might vac it out later tho.
Just back from driving the Evo triangle here in North Wales. Fantastic sunny weather, great scenery and roads too! Porsche 944 tried to stay with us. Failed miserably.
BMW-POWER
Post by BMW-POWER »
today mounted my original bmw sports steering wheel,
and mounted a new chromé grille in front, old one was damaged :D
E10 2002tii 73'
E21 320/6 78' Anthrazitgrau
E30 325i 86' Diamantschwarz
E30 325iC 89' Diamantschwarz
E36 320iC 94' Dunkelblau
E87 118d 05' Havanna
Nothing :mrgreen:
Jason_323i
Post by Jason_323i »
Removed the Alpina b7 spec diff and mocked up the mz3 coupe back boxes
Jason
Z3M Coupe
2.8 Z3 Coupe
Caterham Supersport
