E21 320 M20B27 Running, S/S done, Interior in!
drjim
Re: E21 320 m20b25 project on the go
Post by drjim »
Coil wire gets power from the same place that tells the ECU to switch on. Check your main relay is working.
1982 Saphirblau Baur 325i
Cars all gone!
retro-bmw
Post by retro-bmw »
drjim wrote:Coil wire gets power from the same place that tells the ECU to switch on. Check your main relay is working.
If you mean the three relays which be on the engine I have already changed them but had the same issue?
drjim
Post by drjim »
Check that there is power getting to the relay first then that it works - connect 12v to it and see if it clicks. As I recall the coil wire and ecu power wire both come off that relay.
Cars all gone!
murran
Post by murran »
i think the ecu only clicks the relay in when it sees a crank signal on cranking, same as the fuel pump relay. do you have live to the fuel pump when cranking? this indicates the crank sensor is working and the ecu is reading it correctly.
have you got the crank sensor and cylinder 1 recognition plugs mixed up? they do have the same plugs!
drjim
Post by drjim »
Is your ECU getting +12V to tell it to switch on, pin 27 on the connector goes to a green wire that also connects to the coil. It gets power from the ignition switch directly rather than through the relays, so if you've not got 12V at the coil you have a wiring fault, either where you've joined things up or where all those wires connect up under the steering column.
Cars all gone!
retro-bmw
Post by retro-bmw »
And its ALIVE :D
Seems one of the wires had a brake, fixed it up and it fires up at the turn of the key and sounds sweet just a bit loud ATM due to only having the 6 branch on.
Next on the list is the Interior change will update with what's taking place with the original interior. Once that's done put the exterior back together as it wont be getting painted as soon as I thought due to other projects and time. So will be a bit of spit and shine to make it look a bit fresher.
murran
Post by murran »
its running? yay!!! :)
retro-bmw
E21 320 m20b27 Up and running!
Post by retro-bmw »
murran wrote:its running? yay!!! :)
It is indeed!
Thanks for tips so far guys has been useful.
Now after moving it around the workshop the brakes are a bit of a concern!
What brakes are you guys running on your e21?
Wilwoods, although Volvo 4 pots worked pretty well too
murran
Post by murran »
working and properly adjusted standard rear drums and 323i fronts with green stuff pads.
retro-bmw
Post by retro-bmw »
How good would a standard 323i setup be with good pads and disks?
at least fair, but overhaul the front calipers!
drjim
Post by drjim »
Standard 323i setup is fine for medium trackday use with uprated pads (I used ferodo ds2500's), that was on my blue 316 which obviously only had 110hp but was driven enthusiastically. The slug has about 160 bhp and stopped nicely on 323i fronts (again with ds2500's) and DIY rear golf caliper conversion equivalent to the 323i rear discs. Similar power to the 325 but less weight. I upgraded to Wilwoods because I could rather than because I needed to.
You should be fine with 323i setup, unless you are doing trackdays or rallying.
Jim
Cars all gone!
retro-bmw
Post by retro-bmw »
drjim wrote:Standard 323i setup is fine for medium trackday use with uprated pads (I used ferodo ds2500's), that was on my blue 316 which obviously only had 110hp but was driven enthusiastically. The slug has about 160 bhp and stopped nicely on 323i fronts (again with ds2500's) and DIY rear golf caliper conversion equivalent to the 323i rear discs. Similar power to the 325 but less weight. I upgraded to Wilwoods because I could rather than because I needed to.
Jim
Well it wont be used for the track, more of a daily driver. Going to have to do some shopping for disks and pads!
murran
Post by murran »
id leave the drums but stick some new cyl and shoes on them and make sure the adjusters arnt seized and adjust them properly.
upgrade to 323i calipers/vented discs with some decent fast road pads. green stuff/ferodos drjim mentioned.
people panic about brakes and i dont know why. often going totally over kill.
i mean my old d plate mk2 golf gti i had years ago.... breathed on engine (kent cam audi 2.2 "kv" throttle body 135ishbhp) had standard brakes but with brembo replacement discs/green stuff pads all round. trackday at cadwell park nearly a full hour of hammering round non stop... brakes were solid 100% and i was overtaking mk1 elises and mgf's. i was on one that day.
driving fast round derbyshire in the e21 is no problem on my set up. fast road you can keep the drums just make sure they work and replace the shoes as the linings go hard over time and lose their bite. new fluid etc
