Has anyone removed the rear door cards to check the inner arches. The outer arches may look solid but you really need to remove the door cards. The interior is okay but I think the drivers seat isn't great, the rear headrest don't look original and the passenger seat needs colouring. A leather drivers recaro seat won't be cheap. T1's are fetching decent money but by the time you return this car to original spec, have an engine and gearbox fitted, sort the interior out, get the welding done and then depending on the paint work quality, I think you can pick up a good T1 for around 2.5-3k. You have to ask I guess why someone choose to take the high compression M20 from it instead of restoring the car. There are plenty of High Compression engines available without stripping it from a T1
In my opinion this will never be a sport as you dont have original engine/box.
Cars like these are best to be original.
Thanks Mark.
if anyone else hears of 1
