Control arms.
problemchild75
Re: Control arms.
Post by problemchild75 »
control arms
Eddie.
My E21(s): [O==[][]==O]
Re: Control arms.
Post by Eddie. »
If they're in good nick then yeah?
Kinda don't want to replace old for old though, or are they relatively new?
mr edd
Re: Control arms.
Post by mr edd »
face lift control arms can be fitted to pre facelift cars but need the antiroll bar and the engine crossmember off the facelift car to work....
e21 316 (1981) TRE702X.
Eddie.
Re: Control arms.
Post by Eddie. »
Thought someone said it was just the ARB?
Didn't know anything about the crossmember?
Re: Control arms.
Have you tried all of these suppliers on eBay?
http://www.ebay.co.uk/sch/i.html?_trksi ... &_from=R40
johne21
Re: Control arms.
Post by johne21 »
Fitted late type control arms and 323 anti-roll bar to my 1976 320i, did'nt change crossmember.
1976 e21 320i A4 Alpina #1755
Re: Control arms.
I might even have a 323 ARB you can have?
Eddie.
Re: Control arms.
Post by Eddie. »
e21-Mark wrote:Have you tried all of these suppliers on eBay?
Yeah, the ones in that link seem to be right.
e21-Mark wrote:I might even have a 323 ARB you can have?
Could you have a look, and if so, how much would you be after?
I'd happily upgrade to the 323 ARB, as I'll just get later control arms and some Polybushes, which I'm pretty sure Jamie said he had some of.
Re: Control arms.
I'll check in the morning.
I mailed C3 for you and they can get yours in a few days for £76 each.
Re: Control arms.
I've got a spare 323 ARB here which you can have for free. It's quite heavy though. Where are you based? A friendly forum member might be able to help out in getting it to you?
mr edd
Re: Control arms.
Post by mr edd »
pic of early (top) and later(bottom) crossmembers .. arms connect to crossmember closer to front of car on later cars with later arms (early cars have straight crossmember)...hence crossmember needed as well as arms and antiroll bar to fit later control arms
http://i764.photobucket.com/albums/xx28 ... werres.jpg
Eddie.
Re: Control arms.
Post by Eddie. »
Can anyone confirm if I will need a crossmember or not?
Mark, would you post it if I cover all your costs?
Re: Control arms.
Yes, although Nas might bring it back with him if you ask nicely.
rob0r
Re: Control arms.
Post by rob0r »
I have a brand new set of earlier control arms, £45 delivered
AndyBaur
My E21(s): 1983 320/6 Baur 5-speed (now gone)
Re: Control arms.
Post by AndyBaur »
Just looked at this recommendation - prices look good @ £21.17 each. Don't know the manufacturer Firstline & although I specified a 1982 E21 in the compatibility check, it says 'E21 [1975-1984]' (clearly not right) & in the specifics it says 1975-1978 (obviously the pre-facelift model).
I'm reluctant to order with the details being so ambiguous & contradictory.
All other prices seem to be the same or higher than Walloth & Nesch. Shame I didn't order at the same time as the top mounts. :stupidme
Wasn't there a post that was looking at replaceable balljoints for the control arms?
AndyS
