M15KYY's V8 **FOR SALE**
problemchild75
Re: M15KYY's M60 V8 e21 (rebuild)
Post by problemchild75 »
looks awesome. very tidy garage too considering there is a project going on.
M15KYY
Post by M15KYY »
Ha ha ha thanks guys. i'm an engineer by trade so tidiness is a must in my line of work. its far more productive to have a clear workspace.
E21 316 M60
M15KYY
Re: M15KYY's M60 V8 (e36 m3 evo rear axle fabrication pictur
Post by M15KYY »
im 90% sure this has never been done before so I thought i'd post up some pictures of when I was fabricating the mounts for the e36 m3 rear subframe, this I must stress is not a job for the feint hearted. a lot of cutting and chopping and soooooo much measuring and maths it gave me a headache on many occasion.
I made a tunnel in between the rear wheel arches to put some strength into the body and to support the mounts in the floor, in this picture you can also see the tubes that locate onto the e36 rear carrier.
this shot of the arch you can just see the plates at the back of the sills that I made to hold the front of the rear trailing arm bushes.
apologies for this photo its a little blurry but you can see here the rear beam I welded into the body between the rear arches to hold the rear two subframe mounting points
here is view of the inside from the drivers rear quarter window showing the reinforcing plates to the front of the rear subframe mounting tubes.
and with the carrier in place.
arms in place with the wheel bolted on to show position and arm geometry. (note these oem arms are just for mocking up, top arms will be custom fabricated and the lowers will be D2 camber adjustable.
view from behind showing the arms and carrier in place, shot taken off centre the diff does line up with the tunnel lol
Tubbed rear wheel arches to get that arse lower to the ground and some proper rubber under there.
And just a cool shot of me welding up the rear tubs :D :thumbsup
Thanks for looking. Misky.
E21 316 M60
Looking forward to new update! Love the M60 V8 :mrgreen:
Duracel79
Post by Duracel79 »
Some good work going on there Misky, keep the pics coming :thumbsup
Very interested in how it goes with Surface Processing, I got a quote for getting a new shell sorted with them but want to see some results first.
Its lot to spend when half the car may dissappear due to tinworm e_surprised
Cheers
Ben
M15KYY
Post by M15KYY »
Duracel79 wrote:Some good work going on there Misky, keep the pics coming :thumbsup
Cheers
Ben
been a change of plan now. im using a company in tamworth called envirostrip. they offer the etch primer dip at a sensible price too unlike surface processing who want 1400 plus vat just for the primer. that way the sills and hard to get to areas get coated and protected. check out they're website
E21 316 M60
croma_man
My E21(s): '83 EU 327i
Post by croma_man »
massive work on the whole car, also the M60 is no piece of cake :shock
Cheers
Ben
I was going to use Surface Processing but everytime I spoke to them the price went up!
A guy I deal with ''up north'' builds rally E21 and installs e36 rear ends. Lots of fab work but when you've got the skills I guess it makes sense to use them. :)
Yea not attempted before and looking at that maybe a while if ever it's attempted by someone else! Some nice work there Misky
Duracel79
Post by Duracel79 »
Cheers
Ben
Thanks I've fired them a message to quote me. Mine's a bit different as I want to get rid of all the rot, then repair the shell fit a proper cage with new suspension mountings before having it redipped and coated.
Cheers
Ben
Duracel79
Post by Duracel79 »
Already had a reply/quote and they are very reasonable compared to SP :thumbsup
Ben
M15KYY
Re: M15KYY's M60 V8 post furnacing and interior shots
Post by M15KYY »
Cheers
Ben
Cheers
Ben
glad I could help ben. ideally you want it dipped in primer otherwise it'll be a waste of time as the rust will be back in no time.
the shell before furnacing
the shell after furnacing
back at home on the spit to clean the ash off
Seat bars
E21 316 M60
raseeda green
Re: M15KYY's M60 V8 post furnacing pictures
Post by raseeda green »
Your cars Hot, nice pictures
316 auto raseeda green
323 red m52 modified
raseeda green wrote:Your cars Hot
Badum tsch!
M15KYY
Post by M15KYY »
ha ha ha ha
E21 316 M60
