Great indicators relay fix
Re: electrical problem - indicators
original diagram:
modified diagram with a universal flasher relay for 2*21W bulbs:
bigger picture:
https://farm6.staticflickr.com/5582/152 ... 333f_o.jpg
E21noob
My E21(s): SOLD
Post by E21noob »
Thanks for that. I think this is too advanced for me though. Also, would prefer to keep things orginal if I can.
I tried to mount a newer model indicator stalk with the three prong relay. Indicators worked fine but no flashers in the dash :(
Definitely know it's the relay now!
Found this cheap 4 wire indicator relay on ebay:
http://www.ebay.co.uk/itm/301305252289? ... Track=true
It has the same connections, same power ratings, should work in the BMW, you'll only have to pull the wires with connectors out of its housing and connect them to the relay without housing, because the patern is different.
But it saves a lot of money
E21noob
My E21(s): SOLD
Post by E21noob »
Awesome! Bought one immediately! Thanks again Bertje.
And ?
Does the flasher relay work ?
E21noob
My E21(s): SOLD
Post by E21noob »
Arrived yesterday, fitted today.
Works perfectly!
Just wired the connections like you said, they were even marked with the same numbers on each connector.
Thanks Bertje!
:thumbsup
E21noob
My E21(s): SOLD
Post by E21noob »
Jeroen, I think you should put this in the FAQ section.
Great quick easy & cheap fix for broken indicator relays.
Re: Great indicators relay fix
Done! Copied to Top Tech Topics and linked from FAQ section.
Many thanks to Bertje as well for his contributions!
E21noob
My E21(s): SOLD
Post by E21noob »
Although I have not tried this myself, this may be useful to get the orginal relay working again:
http://www.youtube.com/watch?v=KlVSNX_NaOs
baldy672
My E21(s): 1978 US 320i manual
Post by baldy672 »
I love this fix! I havw the same problem and will be looking for bad grounds & stuff. Does anyone know the details of that 4 terminal flasher? BMW wants $250 for one and I'm all for cobbling in a replacement. I was thinking of making one out of an Arduino board if I couldn't find a cheap fix.
The ebay link is obviously not immensely helpful but maybe someone else has the same part - if I knew what the part number was.
Thanks!
baldy672
Post by baldy672 »
Is this the same thing? h t t p://www.amazon.com/Autotech-4-Pin-Electroni ... B074QHJ8RZ I can't find a suggested wiring diagram for using it with a single indicator but it seems like it might do the same thing. I liked the video post someone added, so I will pull the flasher and try cleaning the relay contacts. The Amazon device is like $9 which is way better than BMW's $250.
Hmmmm I never had any issues there, but there should be enough used relay modules around as well, or not?
The flasher relay on ebay i suggested a few entrys above is cheaper, and we know it works.
Soni would doubt....
baldy672
Post by baldy672 »
BertjeConti wrote: Tue Aug 21, 2018 9:46 am The flasher relay on ebay i suggested a few entrys above is cheaper, and we know it works.
I'd prefer to get one I know works, but that ebay listing was 4 years ago and the 'relisted' link is dead. They didn't show any part numbers unfortunately. I did find it again, but the posting says they won't ship to the U.S. So that kills it for me anyway. :(
