Matts 316
- mcjjordan
- My E21(s): Uk 1980 316 m52
Re: Matts 316
I can certainly add any infomation i can
Still working out some issues
Ie throttle cable,
Inlet elbow,
Plumbing
Ie throttle cable,
Inlet elbow,
Plumbing
- mcjjordan
Re: Matts 316
Re: Matts 316
Good work. what radiator are you using?
E36 328i Daily driver
E36 328i Touring
E36 328i Touring
Re: Matts 316
Nice, how much are they charging if u dont mind me asking
E36 328i Touring
E36 328i Touring
- mcjjordan
Re: Matts 316
No done a few hindred miles in her now. Few teething problems, gear lever has alot of play in it so ended up fitting the old one from the m10.
Fitted a rear arb.
Had to raise rear suspension as it bottomed out under acceleration.
Finally got all the sand out of the geater after engine bay blasting.
Exhaust is very load!
Its fine on motorway but around town when you back off throttle it pops & bangs like mad.
Trying to plumb in additional oil gauges , having trouble finding sendir adapters that will fit.
Still need to get a diff as 4:11 isnt great on motorway (3800 @70mph )
Been trying to find the source of a noise i have in rear when i go over a sharp bump, sounds like a washer somewhere rattling. Its driving me mad!
Have found a local guy who can fab me up a sump guard as im so paranoid about hitting it on our lovely british roads.
Brakes- what brakes?
Realky need an upgrade its scary.
Theyre fine for around town even if a bit stiff but they wont manage an emergency stop .
Fitted a rear arb.
- joe14
- My E21(s): 1983 black 316
Re: Matts 316
Looking like some good work there!
Any chance of a video demonstrating this 'too loud' exhaust, I love it when they pop and bang!
- mcjjordan
Re: Matts 316
Well its been a year since engine went in, drove down to Bummerfest in venlo without a hiccup , santa pod & beaulieu .
All going well,
Still a few bits to do but the big news is i now have brakes!
Yes i was using the standard 316 brakes and totally cooked them on route to holland.
Hi spec in dartford made me a kit up with 285mm discs & 4 pots.
Also have found a device that may help me calibrate the fuel gauge correctly.
All going well,
Re: Matts 316
so Hi-Spec do a bolt on brake upgrade kit for the E21 front? Not a bad idea to move to 285mm. A link to a website? Curious what it'll cost!
- mcjjordan
Re: Matts 316
http://www.hispecmotorsport.co.uk/28524b42.html
But thats not the kit i got as i rang them spoke to alex and we went for larger calipers and modified discs from another vehicle...
Cost wise....
£1000 but they do trade discount
Cost wise....
- mcjjordan
Re: Matts 316
Still worked out alot cheaper than ireland engineering kit
