E9 3.0csi Restoration - Duracel79
Re: E9 3.0csi Restoration - Duracel79
Unbelievable this car was still on the road last year and made it safely to the Sharknose Meeting, such a shame for such a nice car. I'm a big fan of E9's, like the 2000C(S) the most.
Is it the Polaris paint that make these cars so rusty?
But now it's in Ben's good hands, :thumbsup
What kind of welder are you using?
Duracel79
Post by Duracel79 »
And now onto the front end of the sill:
cut out to better metal:
small repair to the floor and inner sill:
The the rest of the inner sill and a bit of box for the jacking point (normally this is not in an E9 but we felt after seeing the structure for the rear jacking support it made sense):
and then the section of the intermediate back on:
Then the bottom of the A post and door frame:
Duracel79
Post by Duracel79 »
Then the outer sill just tacked on for now:
Then we started on the other side which needed a repair to the bottom of the B-Post:
Duracel79
Post by Duracel79 »
Should of mentioned that weld through zinc primer is being used inside the sills before the outer went on:
And that brings us up to New Years 2016/2017.
Cheers
Ben
Great progress! This is the only way to weld it proper.
Mihajlo
My E21(s): 1982 315swap323i
Post by Mihajlo »
:shock
rust bucket is turning to just bucket :popcorn
are you planing to zinc bath the bare shell as you did e21?
Duracel79
Post by Duracel79 »
BertjeConti wrote:Unbelievable this car was still on the road last year and made it safely to the Sharknose Meeting, such a shame for such a nice car. I'm a big fan of E9's, like the 2000C(S) the most.
I'll have to check what the welder is? What I do know is that it is MIG, has a big internal inverter so doesn't overheat with prolonged use and also uses a large reel of wire (IIRC 10kg). Its on wheels for easy movement around the garage, we also needed to fit a 40amp armoured supply cable and breaker for it.
Mihajlo wrote::shock
Yes, when we finish all the metalwork repairs it goes back for another chemical dip then Zinc Galvanize'd bodyshell and e-coat'd panels.
Duracel79
Post by Duracel79 »
Found the info on the Welder:
SWP redline mig 210amp turbo
with 15kg reel of 0.8mm wire
from here:
http://www.ebay.co.uk/itm/SWP-Redline-M ... 3641.l6368
Cheers
Ben
A lot of work already. But I see many more. Good job.
Is getting better and better!!
TopCat
My E21(s): 1980 Alpina B6 2.8
Post by TopCat »
Unbelievable show of skills and a mammoth task. I am so glad it is in such good hands! I had a CSI in the 70's in Germany- absolutely loved it
Regards
Topcat
Isle of Man Inverness
1980 BMW E21 Alpina B6 2.8
1991 BMW E30 Hartge H26
arshad76
Post by arshad76 »
Great work so far. The e3 me and Nas are restoring also needed a fair amount of metal work. Good idea about the ecoating. The e3 was dipped and it,was well,worth the money.
UK Moderator
Duracel79
Post by Duracel79 »
Both rear arch lips have been repaired in the past. Not to our liking as they were welded over the top of the original panel with a 2 inch overlap:
So these were cut off and front quarter sections let in along with repositioning the outer arch repairs:
Duracel79
Post by Duracel79 »
We then moved onto the rear floor repairs:
Duracel79
Post by Duracel79 »
Front floors:
