e21 Glovebox Broken - Help !
e21paddy
My E21(s): 320/6 1981
Re: e21 Glovebox Broken - Help !
Post by e21paddy »
Like so I presume?
Also, https://www.ebay.co.uk/itm/New-Glove-Bo ... SwAvJXB8FL Good to go here?
Yup. That's the most common failure on glovebox locks.
guerciotti
My E21(s): 1981 European 316 1.6
Post by guerciotti »
I've rechecked mine and my I have the catch that is missing from e21paddy's car intact so I can open and close the glovebox by lifting the little metal lever on the glovebox (which is good). My only problem is how to attach the handle.
e21paddy - if you work this out once you receive the catch let me know. My handle looks exactly the same as yours !
The handle screws on from the inside of the glovebox
guerciotti
Apologies for the delay in getting back on this.
I've undone the screws from the inside of the glovebox and this connects the brass component in the picture above. With this off I compared this with the handle in my hand - it would appear that they are connected by a long thin pin or two pins from both sides. Does this sound about right? If so does anyone know the part number for this?
I can’t instantly help you with that part number and I do not know if it can be bought separately. That’s why I swapped the complete handle from an e30 and switched the lock with my own.
