Hello All,
If you want to have a real air filter go the carbon fiber way!
It's the only way to have proper cold air into the AFM, other wise you will have a more eficcient airflow, but with warm air coming from the engine bay!
To have a proper air intake you will have to get an air tunnel from the front grille directed to the air filter and with a carbon fiber case, such as these ones from BMC www.bmcairfilter.com
And they are available to our cars.
Regards
Frederico
and another thing...about teh AFM
hardtailer
Yep, that's why my cone on the 325i is pointing downwards and why I've opened up the front grille more. On the 325i that is. If I want to improve further I guess I should remove the left front high beam unit I guess. Using a A/F ratio meter I should be able to adjust the mixture but the problem is the difference in air flow at different speeds. That's why it'll stay like this for now.
On the 320iS I run the stock intake box and filter. Not sure if changing to the larger lower air box will give any gains... any experiences there?
