MY 323i baur.
- e21-Mark
- E21 Master
Thanks,
I will do my best to get it as nice as possible and indeed those wheels had to go a.s.a.p.
Thanks Cisse,
Now that it's no longer freezing here in holland i can go further with making the car better. For the record, i did know that the car had some problems, according to the price i paid for it. But they are nice cars to drive and the 323i baur is very rare nowedays.
update:
Hey, the ordered parts are in so i can start to make the car run good now.
The complete exhaust, driveshaft revision , engineparts (cambelt,tensioner, waterpump, thermostat, some fuellines etc etc.)
As I bought the original frontseats in colour Anthrazit 091 the two Recaro frontseats are removed. Now I have the space for it I removed the carpet since it is wet and has to dry. The reason why is because the heaterradiator is broken, gladly i have a spare but it's extra work to be done.
When I removed the carpet i did get a little surprise, some rust has been developing and i could see that the car had an accident. The right side has some dents en a rupture of about 4 cm could be seen at the front.
At the passengerside (for me) a metalplate has been welded from the bottemside because of rust. To get it in perfect state I have to restore the car at a later moment. The strange colour of the floorpanels is because of the colout of the leaking coolant
DRIVERSIDE
PASSENGERSIDE
DENT AT THE BOTTEMSIDE OF THE B-STYLE.
RUPTURE RIGHT UNDER THE DASHBOARD IN THE CENTER.
A lott of work to get it perfect but that's for future times.
Greetings Peter V.
DRIVERSIDE
PASSENGERSIDE
Greetings Peter V.
Hey, It's time for an update:
Because i decided to restore the car in a later time a little rustprevention is done at the bottem. I grinded the most of it and then put a coating on it.
After that i placed the isolation back and the cleaned carpet. Offcourse i replaced the heatingunit because of his leaks. With placing the original seats (antrazit 091) the interior was almost finished.
After that I worked on the engine. I replaced the fuellines towards the coldstartinjecteur and towards the pressure-unit. The timebelt, tensioner and waterpump was replaced.
A couple days ago i restored the driveshaft. The support bearing is changed, the guiding sleeve also. This will be mounted with new bolts and safety nuts and also the Hardydisc will be replaced.
Today i recieved the reverselight-switch which is mounted on top of the gearbox so i can mount the driveshaft and exhaustsystem back on the car. Slowly the time is arriving that i can drive the car. I Can't wait.
Hey Stephan,
You are right.
I already bought a piece of body with only a little rust at the jackpoints. Next saturday i am going to collect it.
The piece i bought is from the rearseats towards the front incl the firewall and also the complete Tunnel.
It was a little shock to see the rust but what can you expect when you buy the car and a spare 323i engine for 1000 euros.
I just hope it wil pass the MOT in August so i have a bit more time to collect the spare body parts before the total restauration starts and most important i can drive it.
Greetings Peter
You are right.
Greetings Peter
Hey,
Update 10-3-2009:
Today it was time to drive the BAUR for the first time.
First i had to get used to the suspension, it is a little weak. My 320/6 which i had before had a lowering set and this one is completly original.
But after a while it was enjoying. Offcourse the work is not finished yet but now i can drive it and make sure it's reliable before the first meeting starts.
Greetings Peter V.
Update 10-3-2009:
Greetings Peter V.
- e21-Mark
- E21 Master
Hey,
Thanks, It is not in perfect state but i can drive it now so that is the most important thing.
