Rotaxmaxke's S14 rebuild
rotaxmaxke
Post by rotaxmaxke »
a proud 320is owner
rotaxmaxke
a proud 320is owner
rotaxmaxke
special BMW tool
a proud 320is owner
rotaxmaxke
Tomorrow more pictures if allowed :)
a proud 320is owner
Post by ac/dennis »
Very impressive work! Looking forward to tomorrow, hope I can sleep :D
Finally you show up again :!: Nice and impressive job you're doing ... see you tomorrow :wink:
Gerrit
Great job mate! No expenses spared, right the first time ey?
So, yes, keep them pics coming until the end!
You had professional help with building, balancing, etc?
Also interested in parts specs, what did you use... and we'll be more than interested how she runs after all this!
rotaxmaxke
Today we made again a little bit progress.
water tubes installed
intake
it looks like an engine again :P
a proud 320is owner
Well done 8)
Looks very good.
Peter V
rotaxmaxke
Jeroen wrote:Great job mate! No expenses spared, right the first time ey?
It must be perfect from the first time !
I did the building myself with the help from my brother.
The balancing and new bore was done by a pro. I dont have the machines for it.
Specs ... what do you want to know? :P
a proud 320is owner
Well since apart from the block everyting is new... all of it! :wink:
rotaxmaxke
1 Wössner high performance pistons
2 Schrick camshafts 276° outlet and 284° intake
3 Schrick titanium valve spring retainers + Schrick double valve springs
4 Schrick out and intake valves
5 New OEM Crankshaft 84mm stroke
6 New OEM oilpump with slightly higher oil pressure
7 ...
a proud 320is owner
OK well even though it doesn't look like I will be needing a rebuild in the near future, I might want to ask again when my engine's up for a rebuild. Thinking about having a look at the conrod bearings (drijfstanglagers) though.
About the oil pump, I've heard that the stock S14 oil pump is more sensitive for wear (return valve) hence people advice to place the Sportevo pump. Is that what you fitted?
Can't wait to see and her your machine again, good luck with the last bits 'n bobs!
rotaxmaxke
Jeroen wrote:OK well even though it doesn't look like I will be needing a rebuild in the near future, I might want to ask again when my engine's up for a rebuild. Thinking about having a look at the conrod bearings (drijfstanglagers) though.
If I can help, let me know :wink:
The sportevo pump has no anti-return valve I think ...
But gives 5 bar.
I have placed an extra washer to increase the oil pressure on the new stock pump. :twisted:
a proud 320is owner
