Wilwood 4 pot fitting - walkthrough
As earlier said - pls make a sticky!
Jimi: thanks, if the mounts on the calipers are in about the same position that's true.
323baur: yes boss! :twisted:
--ALPINA--
Post by --ALPINA-- »
Jeroen wrote:Jimi: thanks
No worried hope youget the same type of pipe work as they are the best i reckon and the way to go..
J
cdavie2002
Post by cdavie2002 »
Obviously you are usung vented discs, 22mm?
The Powerlite accepts disc diameters from 240mm to 285mm and 2 disc thickness, solid (9-13mm) or vented (20-22mm). Piston diameters 1.00", 1.25" or 1.38.''
Part Numbers For Ordering:
Part Number-------Bore Size-----------Disc Width
120-8729---------1.38" 35.1mm-------.79"-.86" vented
120-8726---------1.38" 35.1mm-------.35"-.50" solid
120-8728---------1.25" 31.8mm-------.79"-.86" vented
120-8725---------1.25" 31.8mm-------.35"-.50" solid
120-8727---------1.00" 25.4mm-------.79"-.86" vented
120-8724---------1.00" 25.4mm-------.35"-.50" solid
There are a few options of powerlite calipers, which ones have you all gone for?
Chris
1982 320/6 (breaker)
1975 3.0 csi
1974 3.0 csi (donor)
2003 E46
--ALPINA--
Using standard vented discs with the wilwoods and pads fitted is a tight fitting and the disc just about spins freely....
J
tommi_e21
Post by tommi_e21 »
guys please help asap, what is the standard size of the female end of the braided hose i need,
i have converted the willwood using the adaptor so its now male bmw thread but gonna get some pipes made which are double the length of the standard rubber pipes.
rally design will make them for me cheapy cheap, i just dont know the fitting
tommi_e21
Post by tommi_e21 »
rally design have sent me the hoses
cost £10 each plus the silly amount of posting of £9.50, cheaper if buy bulk in future.
gonna get some heat shrink later and cover up the hose to stop tarnishing.
made to order and almost next day delivery
LoCoRaCeR
Post by LoCoRaCeR »
My car is still at the back of a yard 40 miles away. Anyone mind sharing sizes for hoses?T
If you cant do it, and arent willing to learn....pay someone who can!
tommi_e21
Post by tommi_e21 »
call rally design, you need 2 brake hoses 60cm long with m10 x 1 female fittings and then 2 x willwood to metric adaptors, (male imperial end screws in the willy and male m10 x 1 for the pipe.) jobs a good un! should cost you about £35 inc vat and postage, postage is silly so bulk together n get em cheaper
LoCoRaCeR
Post by LoCoRaCeR »
Thank you very much, will get them ordered up shortly. T
Duracel79
Post by Duracel79 »
Plenty of clearance under 13" rims
Also no extra pedal play for me after careful bleeding of the rear brakes.
Ben
tommi_e21
Post by tommi_e21 »
ben get your bum round mine with a brake bleeder then and help me with zans lol
Duracel79
Post by Duracel79 »
austin25uk wrote:ben get your bum round mine with a brake bleeder then and help me with zans lol
Can't do tonight, what about wednesday?
I can give you the brembos then as well
Ben
tommi_e21
Post by tommi_e21 »
errrrr im free wednesday or all sat afternoon and sunday. which ever is easiest for you dude. need a hand getting his bonnet off aswell so i can get to the front to do the cambelt without doing my back in. just gimme a txt
