bmw m52 engine conversion
JJGBMW323
Re: bmw m52 engine conversion
Post by JJGBMW323 »
Car looking great. On the 323i subframe which metal motor arms did you use? The stock M52 ones dont exactly bolt into the 323i subframe. Did you make custom arms?
i used m20 mounts - they bolt straight on.
harleytrike
Post by harleytrike »
Done a few more jobs to stiffen up the chassis fitted new polyurethane anti roll bar bushes front and rear also fitted a rear strut brace. stiffer springs are next to do which are on order along with some ferodo ds2500 brake pads.Image
harleytrike
New ferodo racing pads & stiffer springs arrived today hopefully get them fitted in the next few days.
Ds2500 pads are awesome. Should improve the brakes loads. If the brake fluid is dark then you need to flush all that out before fitting new fluid in.
Be careful when bleeding the system you dont push the pedal all the way down as it makes the seals in the master die if they arent new.
harleytrike
Yep will do also going to get my mate to make a lower chassis front brace
Good idea man. Theres far too much flex there
Indeed! Keep us posted and post lots of pics! :wink:
Any more interior pics?
harleytrike
What interior pics would you like to see mark
As many as you've got.
harleytrike
Going to get a mate to knock me up a chassis support bar in the next few weeks
harleytrike
New brake pads to be fitted should improve things
harleytrike
Made a start on removing the window tints
Looks much better. :thumbsup
