E12 tidy up.
pandemonium001
My E21(s): E12 535i T (ish)
Re: E12 tidy up.
Post by pandemonium001 »
Small update, I moved house on the 27th November and then Xmas so not much done on the car front. but still plugging away at small jobs when i get a chance.
Before i moved i got the engine in:
Mounts made and installed
i centered the engine between the chassis legs using the crank nut and guessed the minimum height for the dry sump to keep the engine low. I can always shim it up a bit.
2 gallon oil tank, an16 fittings, it will probably be sunk down through the panel to provide clearance for the turbo bonnet and lower CoG.
machined and doweled the dry sump pulley
my new plenum arrived, its o.k quality for £200, just needs a bit of internal work.
then cut n shut onto the M30 manifold.
100mm TB
work on the dry sump, its a double taper design with twin scrapers.
welded up and painted with glyptal
triple scavange
came across a second 25% cluster unit so couldnt resist
just need to make an oil manifold to bridge the block's oil ports in the sump before installing the pan. then weld a an10 fitting on the oil filter housing for supply to maintain 50% filtration & instant bearing supply on startup.
elaxo
My E21(s): '78 323i Manueel
Re: E12 tidy up.
Post by elaxo »
love the e12 in combination with these rims , what tires are that?
keep up the good work!
Re: E12 tidy up.
wow! great work, nice details! Did you just clean and brush the gearbox or paited it?
pandemonium001
Re: E12 tidy up.
elaxo wrote:love the e12 in combination with these rims , what tires are that?
Tyres are std front 225/45/17 rear are 245/40/17 the wheels are rc090 front rims with front centers +20mm soacer, rears are rear rims with front centers with no spacer and clears the wishbone by 20mm.
rear arches are only rolled, not streched.
pandemonium001
Re: E12 tidy up.
uwbuurman wrote:wow! great work, nice details! Did you just clean and brush the gearbox or paited it?
gearbox was blanked up, degreased, grit blasted then 2 coats wet on wet with u-pol 2k clear.
only 2 bits starting to cloud after 12 months in storage.
Re: E12 tidy up.
Very nice work!!!
jimbob
Re: E12 tidy up.
Post by jimbob »
Everthing is so clean.
Great work :thumbsup
E36 328i Daily driver
E36 328i Touring
Re: E12 tidy up.
Stunning as always, keep on going.
Love to see this one in real life when ready
Re: E12 tidy up.
Every update is stunning a always, keep em coming!
pandemonium001
Re: E12 tidy up.
Hi Folks,
Still picking at the build when i get a chance.
head has been, cleaned, pressure checked, skimmed 8thou, valves reground and seats cut.
cam position set
new arp studs
Athena coopering HG installed, had to adjust and hold the rings in position with 4 spots of superglue each.
head installed and torqued 30-60-90lbft.
some wrinkle paint
stainless fittings
test fit of manifold
down pipe is going to be creative, prob 3.5" to 2.25" y piece either side the steering column.
test fitted the huge turbo
Holset he531v, in theory best of both worlds exhaust housing adjusts from 9cm to 20cm so fast spool and high top end flow.....but... its huge & heavy, nearly 20kg.
so a Garrett GT4082 due to get rebuilt is in the post, plenty of comressor flow and change the exhaust housing from 1.34 to 0.82 should give me 8psi by 2800rpm
pandemonium001
Re: E12 tidy up.
on the dry sump front:
A bridge manifold is being made for the oil ports in the block where the old pump was.
If i cant get a clockwise direction pressure relief valve for the back of the weaver 4 stg pump, i will just block it off and use an inline petereson relief valve
oil fitting need welded to the oil canister, then a few machining jobs to mount the pump....... somewhere.
Re: E12 tidy up.
:thumbsup
Great progress.
RobK
My E21(s): bmw e12 type1 535i replica
Re: E12 tidy up.
Post by RobK »
WOW... this is gone be a beast!!
Re: E12 tidy up.
Looks great again sir!
arshad76
Re: E12 tidy up.
Post by arshad76 »
That looks lovely indeed
UK Moderator
