Jimbobs graphite 323
jimbob
Re: Jimbobs graphite 323
Post by jimbob »
Ok, just for you :)
E36 328i Daily driver
E36 328i Touring
:thumbsup
jimbob
Post by jimbob »
little bit done today while i was waiting for brake parts
i fitted the freshly powdercoated arb and front polybushes.
much easier than the rears as you can just use longer bolts to force the bushes in
Need to stonechip the front of the tunnel tomorrow before the sound deadening goes on
E36 328i Touring
jimbob
Post by jimbob »
Sound deadening modified and fitted today
E36 328i Touring
jimbob
Post by jimbob »
Hubs, rear discs, driveshafts, handbrake and rear wheels are on
I need to fit the new seals to the rear calipers next and run the two trailing
arm brake pipes to the flexis.
Started to lay out the engine bay brake pipes before they get cleaned and painted :roll:
E36 328i Touring
jimbob
Post by jimbob »
Rear calipers fitted and on wheels
E36 328i Touring
You're at quite a pace mate!
jimbob
Post by jimbob »
Not as fast as id like.
been held up loads waiting for parts, its just nice getting it done :driving
E36 328i Touring
Cool!!!
jimbob
Post by jimbob »
uwbuurman wrote:Cool!!!
cheers
E36 328i Touring
Duracel79
Post by Duracel79 »
Looking good there Jim
I'd let it hibernate in that garage for a few months when you've finished, rather than get it covered in salt and road grime over the winter.
Ben
jimbob
Post by jimbob »
Duracel79 wrote:Looking good there Jim
Ben
yes im not going to get to drive it till spring now, :(
as soon as the engine is in its getting put away
E36 328i Touring
cobbler2u
My E21(s): 323i baur
323i special
328 sport
325i
Post by cobbler2u »
looking good
jimbob
Post by jimbob »
cobbler2u wrote:looking good
Thanks
E36 328i Touring
jimbob
Post by jimbob »
M52 time :crazy
Started replacing all the seals on the engine and built my m50 manifold, changed the green injectors for
the 2.8 pink ones and fitted new seals . changed the seal and fitted the m52 throttle body with an m20
cable attached.
New crank seal and sump gasket to go on the e34 sump
Took the old sump off and the oil pick up then removed the bracket on the windage tray to clear the
new sump
Fitted the e34 pickup with a new gasket and removed the unwanted windage tray from the new sump
ground the remaing rivet heads off and test fitted the sump before it gets steam cleaned
old pilot bearing out and the new one in
made much easier by my friends slide hammer :thumbsup
allso fitted the engine bay brake pipes after they were cleaned and painted body colour but
forgot to get a pic :takepicture
E36 328i Touring
