pandemonium001
My E21(s): E12 535i T (ish)
Re: Mark's M52/2.8 + nitrous
Post by pandemonium001 »
just found this pic in photobucket
Go on Mark you know you want to.
Haha M12 Group 5 turbo, nice!
Went to Pristine today and we started to mock up the engine install for one last time. Now everything fits as it should the mounts etc have all gone for powder coating in black, along with the strut braces. We also fitted the 6 branch which fits remarkably well considering it's an e36 item.
There's way more room with the engine sat at the correct level.
We also dug out the new fuel tank & swirl pot for the track car.
Fits nicely then!
Jeroen wrote:Fits nicely then!
Yes. Losing that huge lump of metal holding the servo and getting the engine sat right has freed up a lot more space.
In the old MIB the elbow from the throttle body would foul the inner wing. There's room to spare now.
The super light flywheel eventually arrived today.
Also plan to make a fibreglass airbox with internal filter and direct cold air feed.
pandemonium001
Who does the flywheel? Fidanza?
Got a couple of updates today. :)
Underside is all protected.
Lightened flywheel & uprated AP clutch on and engine is just about ready for final install.
MIB is definitely coming back together.
:thumbsup
Eddie.
My E21(s): [O==[][]==O]
Post by Eddie. »
So much awesome.
woody m3evo
Post by woody m3evo »
Love your updates mate. :thumbsup
Instagram - WOODYM3EVO
cobbler2u
My E21(s): 323i baur
323i special
328 sport
325i
Post by cobbler2u »
e21-Mark wrote:Going to big wing it.
Bought another 323 today.
Plan to turn this.....
into this.....
Hi Mark seen this is up for sale again. Did you not buy it
No. It failed due to issue with transporter & timing. (nothing to do with the seller who is genuine)
A bit more progress.
The rear beam was cleaned & painted, new handbrake cables fitted and installed with dual billet mounts. The rear LEDA coilovers had been rebuilt by Gaz and the whole lot is now back in the car. Quest Motorsport are tasked with building the exhaust as the old system needs work to clear the new diff install.
New fuel lines, TCA's and braided brake lines. The front LEDA have also had to go for some work but once they're back it'll be a rolling / steering shell once more. Next job is the total re-wiring using the loom from the states.
I know I'm biased but Mick is doing an awesome job. I am really chuffed at the way things are coming along. :)
:thumbsup nice progress again!
