Jimbobs graphite 323
Re: Jimbobs graphite 323
:shake
Nice progress!
jimbob
Post by jimbob »
Thanks guys, its going well :thumbsup
E36 328i Daily driver
E36 328i Touring
jimbob
Post by jimbob »
Cleaned the sump and fitted it with a new gasket today, along with the m20 flywheel and clutch
E36 328i Touring
jimbob
Post by jimbob »
Mounted the gearbox to the engine today along with the m20 starter motor subframe and
steering rack. Got the car on the ramp first and stripped the front end off then put the engine and box on the dolly
had to grind a bit off the block so the starter sat straight
allso got the last two brake lines on and stone chipped the rest of the underside
E36 328i Touring
E21noob
My E21(s): SOLD
Post by E21noob »
Sweet. What motor mounts are you using?
jimbob
Post by jimbob »
E21noob wrote:Sweet. What motor mounts are you using?
Thanks, e21 m20 arms and e30 m20 rubber mounts
E36 328i Touring
E21noob
My E21(s): SOLD
Post by E21noob »
Cool. Calculated, or taking a chance? Not modding the sump either?
jimbob
Post by jimbob »
Sump will need to be modified,it needs to be fitted in the car first so i can see the angle it sits at and how much i need to lose.
borrowed the e30 m20 mount idea from nige21 as it gave him more clearance over the steering rack.
E36 328i Touring
jimbob
Post by jimbob »
Final large parts fitted before it gets stored. Engine gearbox and prop all on :boogie
The stone chip has dried now and looks great just need to bolt the front brake lines and cluth up
spring needs to hurry :twisted: :twisted: :twisted:
E36 328i Touring
cobbler2u
My E21(s): 323i baur
323i special
328 sport
325i
Post by cobbler2u »
what stone chip you useing
jimbob
Post by jimbob »
upol gravitex. sprayed through a gun, it drys to a matte finish so you can still see all the detail and you can
paint over it if you want
i need to get some good shots of the underside, you can just make it out in this one
E36 328i Touring
That sump is sitting too near the ground.
jimbob
Post by jimbob »
yes it is, if you read the posts its been fitted to determine the level it needs to be cut at :thumbsup
and so i can start the car when all the small bits are sorted because im a big kid and cant wait :playcar
E36 328i Touring
jimbob
Post by jimbob »
Winter home cleaned out and car delivered
E36 328i Touring
