They took the complete box apart. All worn parts will be new, O rings, gaskest, clutchpaks, torque convertor, the works.
A steel O ring was broken into pieces, was laying in the oilpan, the frictionmaterial on the clutchpacks was gone. Burned away. In 1988 ZF had a update for the 4HP22. before 1988 the boxes couldn't
handle revving in N of P. that would blow out the seals and Orings because the pressure could not get out. The solution is to drill a hole and replace two steel rings for plastic ones. So that will be done aswell.
and now pictures!
new torque convertor
Old O rings and a stack of old gaskets
Burned frictionplate vs a new one.
Some loose parts
and a bearing that was damaged an damaged the house it was placed in, so that needed replacing. Bummer.
Wearmarks on the inside.
The brain and end piece still needed cleaning.
the brain will be taken apart also.
all new gaskets. Those white rings are the replacement for the steel ones, due to that rev problem in N or P.
[/URL]
