Eddie's E21 316
Eddie.
My E21(s): [O==[][]==O]
Re: Eddie's E21 316
Post by Eddie. »
The chrome came off the rears before the glass, I've been refitting things in the reverse order to how they came off.
If its easier to fit with the chrome in place, then I'll pop them out, of all the windows, they were the easiest to fit by far.
Eddie.
Re: Eddie's E21 316
Post by Eddie. »
Having had a look, you're right, the chrome winglets should have gone in before the glass! My bad! :oops:
Got started on the wheels today.
This will probably a fairly long job :(
This is how they started:
Then, with the help of this:
I did this:
Need to find somewhere that sells a decent primer and then get some paint on them. Judging by my 182 wheels on the RB, these should look good :)
denis9
Re: Eddie's E21 316
Post by denis9 »
How long were you at that wheel then to get to that stage?
Eddie.
Re: Eddie's E21 316
Post by Eddie. »
About an hour or so? Maybe a little longer.
There's a fair amount of paint on them, so I'm making sure it's all level and keyed up.
Eddie.
Re: Eddie's E21 316
Post by Eddie. »
Chrome trim fitted today, had a bit of a nightmare with the trim on the side glass, but we got there.
Also, new rubber stop for the petrol cap:
New pins for the door check arms:
Should get a fair bit more done tomorrow.
Eddie.
Re: Eddie's E21 316
Post by Eddie. »
Did the sunroof today, sounds an easy job, but I wasn't the one who removed it, and it was pretty tricky to get it fitted. Two minds make light work of it though and my mate was round to help out :)
Needed to recover the underside of the sunroof before fitting it.
New headlining:
After some head scratching a bit of fiddling, we got there:
Need to order a new door window seal as the passenger one is a bit rubbish.
Very little left to do on the exterior now.
Re: Eddie's E21 316
Getting close now! :thumbsup
arshad76
Re: Eddie's E21 316
Post by arshad76 »
Hey Eddie,
Nice seeing you the other week, really looking forward to seeing this back on the road - first rate work by the way.
UK Moderator
Eddie.
Re: Eddie's E21 316
Post by Eddie. »
Yep, not far off now :)
Got some of the underlay in yesterday:
Eddie.
Re: Eddie's E21 316
Post by Eddie. »
Time for some decent progress updates.
Did the dash and heater system tonight.
Dash with vents all fitted:
Heater matrix fitted (car is crying for a clean!):
Dash & heater matrix fitted:
Been a while since I've had the lamps out!
Holiday next week, then I'll hammer it when I come back.
Eddie.
Re: Eddie's E21 316
Post by Eddie. »
Got some work done recently:
Manky wiper arms painted black and fitted to the car, along with the scuttle panel and washer jets:
Also purchased some vehicle dollies. They're really good quality from the looks of it, and make moving the car a lot easier, although the movement is a little hard to master!
I've also sorted most of the poor fitment of the wing too. It was sticking out a long way at the base, I'm attributing this to the fact the wings are non OEM.
Anyway, I drilled a 6mm hole in the wing, and the side of the jacking point, then put a bolt through it and a nut on the back, and voila, it worked perfectly.
The bolt is tucked away under the sill too, so you can barely see it.
The passengar side was a little trickier, the wing was sitting lower down and wouldn't bolt straight into the jacking point.
This may look quite rig up, but it's done as neatly as possible.
I made a bracket, and drilled it so it could be bolted to the jacking point, I then drilled it again lower down to allow the wing to bolt up to it.
Worked a treat :)
That's all for now, and pretty much all the exterior done, bar the rear bumper and a few bits that need sorting in the wheelarch.
Speaker wiring should be going in very soon, then I can finish the dash and get cracking with the carpet :)
Re: Eddie's E21 316
Glad its sorted, but the fitment of these panels appears to be way off. W&N metal, correct?
Eddie.
Re: Eddie's E21 316
Post by Eddie. »
Jeroen wrote:Glad its sorted, but the fitment of these panels appears to be way off. W&N metal, correct?
That's correct.
arshad76
Re: Eddie's E21 316
Post by arshad76 »
Good work Eddie, if you haven't already sorted your wiperarms, I have a pair of ones I had powdercoated recently. Didn't dawn on me that they differ between left and right hand drive cars, so can't use them on mine :screwy
UK Moderator
problemchild75
Re: Eddie's E21 316
Post by problemchild75 »
Im going to powdercoaters tomorrow if you need anything taking
