Duracel79
Re: S54 Powered 323i - Duracel79 - England
Post by Duracel79 »
Progress has been made :thumbsup
Out with the old :protest and in with the new :innocent
New gearbox all fitted up. Needed new spigot bearing for the larger pinion. Also fitted a Sachs 618 clutch cover to the lightened 323i flywheel with the six paddle solid centre.
Twisted the linkage and it broke so improvised.
back in the car with plenty of clearance in the tunnel. Not really any tighter than the E30 260 box
underneath with e30 rear mounting plate and solid alloy mounts
And my nice shiny rebuild and uprated LSD all ready to go in.
Just waiting for the propshaft to be finished (new length again but with larger donut mountings) and returned, hopfully this week.
then its refit the exhaust, wiring fuel & oil pipes.
Cheers
Ben
Danny043
Post by Danny043 »
Good work!
I can't help but notice the bolts on your shiny good looking LSD are rusty :read
Anyway, what LSD is it, large case E12 ?
problemchild75
Post by problemchild75 »
awesome :mrgreen:
Duracel79
Post by Duracel79 »
Danny043 wrote:Good work!
Exactly what my dad said, "He could of at least cleaned the bolts up?"
To be fair I think my phone camera shows them up much more orange than they are. But its all getting hidden under the car which is certainly not a show queen :innocent
This is an early Sideloader LSD from an E9 in 3.25:1 ratio (note the bolt in output flanges rather than the snap in versions which come in later E12 sideloader diffs). The LSD carrier has had teh ramps modified for 40% lockup and new clutch packs fitted. the bearings where all checked/cleaned and the diff all shimmed up correctly. It'll work nicely with the E36 gearbox and its 1:1 ratio 5th gear.
Ben
rob0r
Post by rob0r »
Awesome work. I can't imagine how fast it is!
Great job so far! Looks like enough ground clearance?
Duracel79
Post by Duracel79 »
uwbuurman wrote:Great job so far! Looks like enough ground clearance?
It is a bit high at the moment. Its still set for everything to be above ~100mm for the regulations I used to race to. No problems with any speed bumps at the moment. It'll be coming down once I set it up for the track again.
On that note, looks like the first blast of the S54 on track will be at the BMW CC day at Snetterton 1st March. I can't wait.
Ben
We want video coverage of that event!!!!
mrd
Post by mrd »
Which E36 gearbox you are using? Was it hard connecting the wiring loom?
Duracel79
Post by Duracel79 »
Gearbox is a ZF unit from either:
328i
M3 5 speed
or late 323i tourers
Its a much stronger box than the Getrag units found in other E36's.
As for the wiring loom, making wire connections is easy once you know which wires come from what on the engine and you know which pins to attach to in the aftermarket ECU. It's only making about 20 connections from one loom to another.
It'd probably be easier to connect an original complete S54 engine loom with original BMW ECU. Then have the ECu reflashed to remove the EWS and any other non required functions. You'd only need to make connections for about 6 wires then.
Ben
Duracel79
Post by Duracel79 »
Jeroen wrote:We want video coverage of that event!!!!
Good news, I've just ordered a GoPro Hero Camera so there will be onboard video :thumbsup
Ben
Duracel79
Post by Duracel79 »
First vid, took me an hour to load.
Keeping it around 6.5krpm max:
Ben
cobbler2u
My E21(s): 323i baur
323i special
328 sport
325i
Post by cobbler2u »
sounds great
Excellent. Sounds great as ever.
Lars-Nord
Post by Lars-Nord »
Like. Like a lot. ;-)
81 e21 323i polaris
