DrGonzoPOW's 1981 320/6 - 325i -Race'in Up-
Re: DrGonzoPOW's 1981 320/6 - M20B25 conversion
murran wrote:as 'ere forum talked you into this engine swap stuff.... its only right one of us helps you along with it.
plus i wana see the smile on your face when you set off from a junction with a shit load of tyre smoke piling out of a rear wheel arch!
Kudos to Mr Murran for stepping in an lending a hand. IMO that's what forums/enthusiasts are all about. Helping each other out.
It'll be great to feel the night & day difference in performance that'll make all the hard work worthwhile! :thumbsup
DrGonzoPOW
Post by DrGonzoPOW »
Haha,Kudos indeed! Your in high demand now Murran!
Where abouts is Rossendale Jacko ?? Any help is always appreciated and like ive mentioned before, all the gear we have at the unit - welders, paint guns, air tools etc..people are more than welcome to use if needs be too
Wakefield Hellfire
Jacko
Post by Jacko »
DrGonzoPOW wrote:Where abouts is Rossendale Jacko ??
Live in Haslingden and my unit is in Waterfoot.
DrGonzoPOW
Is that north of Manc ??
Wakefield Hellfire
DrGonzoPOW
Couple of bits done this morning. Refurbed the headlight housing/cups and surrounds in satin black. Came out pretty nice
Put all the grill (de-badged) back together. The front panel has been sprayed and laquered too, makes a big difference.
Wakefield Hellfire
murran
Post by murran »
headlamp brackets look nice!
so when are we doing the rest of it? cant do this weekend btw......
That first drive with 170 brake is drawing ever nearer. :)
DrGonzoPOW
It is mate, just need Murrans help once again with the wiring and fingers crossed it'll be running
Wakefield Hellfire
Reck
Post by Reck »
Not checked this thread for ages. Nice work!!
DrGonzoPOW
Cheer Reck, Its going slowly but coming along now.
Regarding the fuel pump. Im having a bit of trouble getting it to screw into where the old sender unit came out. Does it just need some persuasion or do i need to shorten it ?
Wakefield Hellfire
which fuel pump are you using? make sure you havent accidently left the old rubber on the edge of hole on top of the tank.
you have to kind of press it down and tap it round at the same time.
murran
Post by murran »
i had to shorten mine by about 8-10mm. but, the one i put in drjims just went straight in????? same e30 318i/is in tank pump.
does the pump hit the bottom of the tank before you can screw it down?
DrGonzoPOW
Yeah, there looks to be some kind of tub type thing in the tank where the pump/sender sits and it's touching the bottom of that and just stopping me from screwing it in. Does'nt seem any longer than the original sender though. May just need to use a tad more force, just worried about breaking something.
Wakefield Hellfire
murran
Post by murran »
hammer?
drjim
Post by drjim »
Hard to break hammers mate.
1982 Saphirblau Baur 325i
Cars all gone!
