BMW E21 327i (second racetrack video)
- croma_man
- My E21(s): '83 EU 327i
Re: BMW E21 327i (Looniticz INC final stroker pics)
thanks guys! If I could spend here a whole day it wouldn't be enough, so many ideas...
one of best. just your seats looks to new for me
How do the stiffer rear springs go? I have the same problem with my E21:croma_man wrote:
some stiffer springs for the rear, stroker kicks in very hard
- croma_man
working all day every day...didn't have time to fit them yet
Especially the rears aren't much work!
- croma_man
next excuse, it's always raining when I get to the workshop, can't drive in the rainJeroen wrote:Especially the rears aren't much work!
Well let me return then, you don't need a workshop for the rears! Changed them on the street many times: loosen the three top nuts slightly on each side, then jack it up slightly under rear axle or diff. As soon as you see the tension is off the tops you're high enough already, wheels will still be touching the ground. Then you undo the lower bolt, remove the 3 top nuts and the entire package is off the car.
In my younger years changing both of them didn't take more than 15 mins!
Sounds almost too easy! Pretty well the same on an R33 skyline (and probably other IRS nissans)
Microang
- My E21(s): 1981 BMW 320/6 E21 Manual Sunroof
I must say this has to be my favourite build on here, such attention to detail!
Is the steering wheel from a e24 and did it require modification to fit?
Also you say you're using an M20B20 block? What is your engine exactly?
Look forward to seeing more...
- croma_man
thanks mate !Microang wrote:I must say this has to be my favourite build on here, such attention to detail!
Steering wheel is from a E30 (with some force, it fitted)
This is a genuine ETA M20B27 with high compression block, crank and pistons, and M20B25 head with a lot of modifications.
- croma_man
this month its driving only, and god I love to drive it
and I did a few pics
beauty!!!
Fitment of wheels is perfect
Microang
Man I want those wheels!
