Pandemoniums 316 restore
problemchild75
Re: Pandemoniums 316 restore
Post by problemchild75 »
great minds and all that lol
pandemonium001
My E21(s): E12 535i T (ish)
Post by pandemonium001 »
The guy selling sounds brand new, txt him from his for sale add on wheel whores before he put them on ebay, they will be wide i think they were on a corrado with 20mm spacers before so et=0, they looked wide on that. needed to decide on wheels so i can form the arches before external paint.
yeah i initially saw them on WH.
I reckon that your in the best place for these rims even if they poke out an inch or so then as your car is getting overhauled you may as well extend the arches to fit the wheels.
Nas
pandemonium001
an hour here and there, started cleaning the glue off and removing the mangled seat supports
my new favorite toy, i knew i bought it for a reason.
before
after
not bad for £35
OMG how much filler do you need??
pandemonium001
dare to be different, the new Msport euro look, will be better with a tiny bit of -ve camber :loll
Mihajlo
My E21(s): 1982 315swap323i
Post by Mihajlo »
:shock
brand? size? offset? price?
Speak now man!!!
pandemonium001
IMAGE BILLET 26 3 PIECE RIMS
16X8.5 Tyre installed Nankang 205-40-16
16x7 Tyre installed toyo proxi t1r
WEIGHT 8.5j 15.4KG each with tyre.
offset 20mm 4x100
ceramic coated outer flange
price brand new from image £1600 ish plus delivery and tyres. i paid a lot less. thats why the car will be made to fit the wheels if required :loll
damnit lol they have fit really nice.
did u need spacers on the front of did they go straight on?
problemchild75
loool they will fit well on a bare shell with no running gear. the wheels are sweet im interested to see how you get on fitting them so hurry up :mrgreen:
pandemonium001
i will try and get the engine off the subframe tommorrow and see if they clear the track rod ends.
i was waiting to see if anyone noticed that there was no running gear installed :loll
more pics tommorrow night.
Mihajlo
Post by Mihajlo »
I noticed but it's too late now :oops:
:mrgreen:
pandemonium001
got a bit done today, but i managed to twist my back getting into the car.
removed more seam sealer from inside the shell
removed the passenger side sill, it will need a bit of work to the inner sill after some botched repairs
started cleaning all the underseal from the front wheel arches.
only got about 3-4 hours done as my back was hurting to much, will see how it is tommorrow and get a bit more done.
pandemonium001
started on the worst side first where there had been botched replacement steel that was rotting away, cut back to the origional positions that PO cut the first time.
here is progress so far.
this is how both sideswhere left with silicone sealer stuffed in the gap.
to this
started cleaning the front
previous damage
inside
bit of rot at the front but not to bad
will start the rear arches next, clean up the flages a lot more, remove more surface rust. then start repairs from the inner sill to the floor pan working out.
measured the replacement pattern sills they are only 20 guage, but i will be fabricating inner sill and stiffner rib repairs in 18 guage.
pandemonium001
managed to get some more done lately.
getting there slowly. still need to tidy some welds up.
Yeah but a whole lot better already! Are you going to replace the rusted part of the floor pan by an original part as well?
