WANTED E30 SPORT
Re: WANTED E30 SPORT
There's no difference between the engine in a 325 sport to a 325 auto or a 325 cabriolet. The only variations of 2.5/m20 are high or low compression.
cobbler2u
My E21(s): 323i baur
323i special
328 sport
325i
Post by cobbler2u »
I know there's no difference. But if a car has had it's heart taken out to me it's not the same.
Others may not mind but I want an original car with the right bits on
nuke laars
My E21(s): 1983 Baltic Blau 316
Post by nuke laars »
Mobster wrote:Has anyone removed the rear door cards to check the inner arches. The outer arches may look solid but you really need to remove the door cards.
THIS ^^^
Further than that you ideally need to take the side skirts off as they allow dirt and salt to fester there and rotting the sills if not removed and cleaned annually (mostly never happens). The front bulkhead needs close inspection along with signs of bodged repairs in the scuttle, under the transportation pads at the front (mistakenly called/used as jacking points), rear valance, flitch panels and the biggest killer of E30s a crusty roof - hit the headlining and listen out for flakes of rust.
It's no secret that sports values are on the rise which could mean that there will be MOT dodging cars being fillered up and will be sold on as mint. Mint sports are like hen's teeth. It is definitely a case of 'caveat emptor' when buying a sport, if you don't know what you're lookng for take someone who does.
1983 Arctic Blau 316
1989 Sterling Silber 318i
cobbler2u
323i special
328 sport
325i
Post by cobbler2u »
Still looking :(
goldbmwe21323i
My E21(s): 1982 323i, E30 325i Cab
Post by goldbmwe21323i »
bruv theres a white one on e30zone
PURE E21!
Car Sales of all makes and models
www.crestmotors.co.uk
ON THE LOOK OUT FOR MY OLD ONE BLACK MHX117X
cobbler2u
323i special
328 sport
325i
Post by cobbler2u »
cheers seen it
