What do you mean, the slidingpart of the headliner? That hooks on to the rear of the sunroof. At the sideThe two rods with the U bar in between jus slides, does not do anything, because it is de water drain when closed. Gets rain/washwater to the sides, where the drainholes are.TaylorGoesFast wrote: Mon Nov 16, 2020 3:34 pm
The other issue is, I can't figure out how the rear of the sunroof panel is supposed to connect. I have it connected to the panel slider rail with those rods, but it doesn't seem to tilt when the sunroof itself does because the tabs on the sunroof panel don't hook over that roller. It's really frustrating because the headliner gets destroyed immediately when messing with this stuff.
Be sure to test those. The two in the rear drain behind the chrome behind the side windows. The front two in rhe sills, which will guarantee rust inside the sills. So I recommend getting a lot of ML or a product like it inside those.
