320/4 with starting / Solex problems
E21-driver
My E21(s): BMW E21 315
Re: 320/4 with starting / Solex problems
Post by E21-driver »
Guys,
after coming back from my holiday , I started to work again on my engine problem. Please have a look on this enrichment valve of the Solex carb.
The service kit was new. But there is a hole in the new diaphragm ! I have never seen it when I put it in. But after detailed search in found this picture in front of me:
This means it is defect ? Could be the reason why it was running too rich permanently ?
And what about the small washer, should it be under the nut or under the diaphragm ?
I am not so sure if this is assembled correctly. Maybe also Peter can have a look on it ? Thanks.
M.
1982 315 reseda
E21-driver
Hi guys,
New results in this issue. I had a Weber 32/36 DGAV on my shelf, so I decided to put in a rebuild kit and to install it into the engine. Just to see if the engine really is ok. After twenty minutes I could start it, and it was running and idling like never before. I used additionally a carb pressure regulator from Sytec and the system works now.
I identify these root causes of my long lasting problem.
The Solex housing is warped at different places, I would say nearly in all sealing areas. So I trimmed them all on a glass plate, and the problem was much clearer visible. You couldn't see with with the eyes, but with a bright LED lamp.
Second cause was the stock 320 fuel pump. It was delivering too much fuel without using the return line and the return valve. I don't have a return line, because the car is originally a 315. But I could solve it with the regulator. I am sure that the ETK has not the right information concerning the pump.
Third reason - I am not 100% sure - may be the enrichment diaphragm. See the picture of my previous post. I put it from Solex one to Solex two, so I obviously installed a problem from one to the next. All pictures I saw for the BMW diaphragm were wihout this hole. And also an old one which I took out of the Solex.
So my patience was really exhausted, but at the end I am happy to see that iginiton and engine are working now, and I have learned a lot about Solex issues. I will use the Weber for a while....but the Solex story will not end here. I will bring it to a running condition.
In the next days, I will tune ignition, valve clearance and CO and then I will see how good the Weber is working.
Maybe somebody has an info about this mysterious diaphragm ?
M.
1982 315 reseda
At least you made huge progress for now, good news!
E21-driver
I am going to have fun for the next weeks.
I want to thank you and the other guys for the help, I will report again.
M.
1982 315 reseda
Great news that the weber setup is working fine. At least you can drive it now. As for the diaphragm.....
That hole is not OK, I have a picture of the normal setup and there it is not. The washer and nut are OK that way
E21-driver
Thank you Peter for the picture, I have checked again the Solex manual. If there is a hole in the diaphragm, the enrichment valve can not be closed by a permanent vacuum. This means, it stays open also in idle mode and will permanently enrich the mixture.
I am also sure that BMW version is without hole, but I have seen this part some times with hole. There seem to be cars also with this hole.
M.
1982 315 reseda
E21-driver
Hi guys,
at the weekend, I adjusted also ingition timing, and the car runs very smooth now. Very happy with the result. Does somebody know, how the electric choke works ? Same as in Solex ?
Step 1: when engine is cold (under a certain sensor temp.), the sensor is open, 12V are not available at the electric choke, the choke flap is closed.
Step 2: when engine is warm (over a certain sensor temp.), the sensor is closed, 12V are availabe at the electric choke, the choke flap opens.
Am I right ?
1982 315 reseda
Indeed it looks like the system is the same as the solex.
