Little by little with 320i 1/77
Re: Little by little with 320i 1/77
Still under construction.
All pics moved here. http://basso72.1g.fi/kuvat/e21+320i+VESseli/
78 beemergal
- Newbee
Thank you I can finally access the link to see the photos - great work. I am out of the states - California to be precise and wish I knew someone with your abilities here. I have a 78 320i automatic and it has some rust that needs to be worked on but most bodyshops here just throw a bunch of bondo on the vehicle only for the rust to return down the line. Thanks again for the opportunity to see the job done proper.
78 beemergal
78 beemergal
Top class work - is this mechanical fuel injection?
1976 e21 320i A4 Alpina #1755
Original K-jet.johne21 wrote:Top class work - is this mechanical fuel injection?
Hiya, well yeah sadly that's how we know US restorations but surely there must be some fanatic out there? How about these guys in the larger LA area, they know their 02's and E21's! http://www.2002ad.com/78 beemergal wrote:Thank you I can finally access the link to see the photos - great work. I am out of the states - California to be precise and wish I knew someone with your abilities here. I have a 78 320i automatic and it has some rust that needs to be worked on but most bodyshops here just throw a bunch of bondo on the vehicle only for the rust to return down the line. Thanks again for the opportunity to see the job done proper.
78 beemergal
Some pics...
- arshad76
Was going to say the same as Jeroen, nice neat work there!
UK Moderator
Not much happened but sometimes little progress..
Not bad! I see you're going for the shifter lock as well, I installed it in my E21 as well.
Beautiful. Nice work.
What did you use to underseal??
inspirationally clean good job!!
reminds me of when i did my kashmir gold 316, stunning work pal and great attention to detail. love it
E21 316 M60
Yes,it's pretty rare "original zübehör" and fit nice behind new 5-speed Getrag 240...Jeroen wrote:Not bad! I see you're going for the shifter lock as well, I installed it in my E21 as well.
2K EpoxyLeeLee wrote:What did you use to underseal??
Then,I thought it was Dinitrol 445 (or some similar) http://www.rust.co.uk/012-dinitrol-445- ... p/p497377/
And last,black 2k PU-paint.
