E21 front brake upgrades
- Jason_323i
Re: E21 brake upgrade
I know there wrong because i bought a set about 5 years ago
Jason
Jason
Z3M Coupe
2.8 Z3 Coupe
Caterham Supersport
Z3M Coupe
2.8 Z3 Coupe
Caterham Supersport
- TopCat
Have a look at HiSpec link below:
http://www.hispecbrake.co.uk/E30%20284m ... t%204.html
I know this particular kit is E30 designed= but they are flexible and able to make up bespoke stuff. Their stuff is pretty good.
We use their discs in the race Camaro- quite an effort as we are only allowed 15" rims- and the car takes some stopping!
Regards
Topcat
Isle of Man Inverness
1980 BMW E21 Alpina B6 2.8
1991 BMW E30 Hartge H26
Topcat
GixxerBob99
- E21 starter
Any one on here have any views on these calipers ? They look ok and they are based 2 miles from my house.
- e21-Mark
- E21 Master
GixxerBob99
- E21 starter
Sorry the hi spec ones..
- TopCat
very happy with the discs (now)
don't have any experience of their calipers (we have Willwoods)
Regards
Topcat
Topcat
- e21-Mark
- E21 Master
I'd go with Wilwoods. Even without considering their price they're good bits of kit.
Re:
I'm now in the middle of this conversion, one side done.jrcook320 wrote:I have done this conversion. It was fairly straight forward, but the calipers I bought overhung the rotors by exactly 7mm, not the 3mm that I often see posted. I had to slot them to get them down to 1mm overhang (I used a carbide bit and die grinder), and also used 1.5mm washers to center the calipers on the rotor. I actually went to the hardware store with calipers (measuring calipers) and measured washers to make sure I had all the same thickness (washers tolerances aren't too tight). I bought my calipers brand new for about $60 USD each at http://fcpgroton.com/volvo240brake.htm, but prices have gone up since then. I bought part #5002028X and 5002029X, a hardware kit, and metal master pads.
I can't figure out what is the purpose of the two extra bleed nipples haly-way up the front of the caliper, ( as can be seen in your pics)
What is their purpose, and is there a specific procedure for bleeding ?
Ta !
The calipers have 4 bleed nipples as they are universal... they may be upside down on the other side, right? Just bleed the top ones and always start with the caliper that has to cover the longest distance brakeline wise.With my Wilwoods, I had to re-bleed them 2 or 3 times before all the air was out. Just do some driving and bleed again the next day or week.
Quite simple really ! Now why couldn't I think of that !Jeroen wrote:The calipers have 4 bleed nipples as they are universal... they may be upside down on the other side, right? Just bleed the top ones and always start with the caliper that has to cover the longest distance brakeline wise.With my Wilwoods, I had to re-bleed them 2 or 3 times before all the air was out. Just do some driving and bleed again the next day or week.
Thanks
More front brake upgrade options: http://www.bmwe21.net/forum/viewtopic.php?f=3&t=20098
Re: E21 front brake upgrades
This looks like an affordable kit to me, 300mm E21 front conversion rotors and calipers (Wilwood) that fit most 15" wheels, complete kit
http://www.massivebrakes.com/brake-syst ... _front_300
- mcjjordan
- My E21(s): Uk 1980 316 m52
Anyone got any sensibly priced upgrades?
Did i read somewhere about some australian calipers?
Volvo 4 pots. Used or remanufactured, they're not expensive.
