Wilwood 4 pot fitting - walkthrough
- tyson 320i/323i
I've a set for sale!tyson 320i/323i wrote:i asked this earlier and somehow it got deleted. where can i find the specs for these adaptors. i have access to machining equipment, so i just need a drawing to go off of. hell- i'd even buy a set if anybodies got a set they dont want
plse sent a pm for more details.
EBC now do pads for the wilwood powerlite calipers.
Greens @ ~£50
Yellows @ ~£70
Email received today below:
Hi
Part number required is DP4057R
Greens are also available DP2057 however we only recommend Yellows for any track work.
Both part numbers are here:
http://www.ebcbrakesdirect.com/search/d ... v1=car&t1=
What is you forum web address?
Regards
EBC Brakes Direct Limited
Office opening hours Monday to Friday, 9am to 5pm
EBC Brakes Direct is an independent company and not owned or operated by EBC Brakes nor Freeman Automotive.
We are a master distributor for their products.
Greens @ ~£50
Yellows @ ~£70
Hi
Regards
- e21-Mark
- E21 Master
- tyson 320i/323i
- e21-Mark
- E21 Master
They'll do a discount for the forum as well
see below:
Ben
Hi
We would be very pleased to offer your forum users a 15% total discount.
This would be by means of a promo code to use online only.
Once you have finished selecting your items and are viewing the cart contents, please enter
BMWE21HY79767
into the promo code field for the discounts mentioned. The code is tested and working.
Regards
(PLEASE REPLY WITH HISTORY ON ALL EMAIL COMMUNICATION)
see below:
Ben
Hi
BMWE21HY79767
Regards
- e21-Mark
- E21 Master
Re: Wilwood 4 pot fitting - walkthrough
Does anyone have details of supplier / part numbers etc, for the braided hoses used here? Please PM details asap. Thanks
- e21-Mark
- E21 Master
Seems I deleted these.e21-Mark wrote:Does anyone have details of supplier / part numbers etc, for the braided hoses used here? Please PM details asap. Thanks
evening all just wandering whats the best brake pads to use with these calipers with standard 323i disc thanks
I wasn't to pleased with Wilwood's fast road pads, but nowadays you can get Ferodo DS2500 for the Powerlite 120-8729 4 piston unit and they are pretty good for both road and the occasional trackday. I used them myself for a few track laps and on 2 trips to the Alps already. Ferodo model FRP3108.
So, is anyone going to post the brackets blueprint? Would really appreciate that!
fitted these today with green stuff brake pads what a differance stops quicker and no more stickin calipers
