BMW-POWER'S 78' E21 320/6
BMW-POWER
Re: BMW-POWER'S 78' E21 320/6
Post by BMW-POWER »
some pica's,
the reason why i want to fit this rear axle is because i have plans for mounting a hydraulic handbrake :)
E10 2002tii 73'
E21 320/6 78' Anthrazitgrau
E30 325i 86' Diamantschwarz
E30 325iC 89' Diamantschwarz
E36 320iC 94' Dunkelblau
E87 118d 05' Havanna
For that construction you need to seperate the handbrake and normal brakesystem then?
BMW-POWER
Post by BMW-POWER »
i think that everything has to do with cable handbrake has to be removed, and the hydraulic handbrake works on the same circuit with the brake caliper
except the two front wishbones, i have all the parts for a complete 323i suspension swap
this evening went for a 323i torsion axle :D
front strut legs are being sandblasted, brake calipers are also ready to be mounted with new gaskets and rubbers :D
E10 2002tii 73'
BMW-POWER
Post by BMW-POWER »
time for another update, front struts are ready, only have to fit the brake jaws + the billies and the H&R springs and we can mount that stuff
E10 2002tii 73'
BMW-POWER
Post by BMW-POWER »
today had some time to fit the billies and the wheel bearings
crappy job to fit the shocks in the struts :?
nnew bearings, fresh grease and new gasket rings :D
coming week mount the brake jaws and h&r springs, then finding some time to fit the parts on the shark
still looking for brake disks and pads, anyone proposes for good combinations?
E10 2002tii 73'
BMW-POWER
Post by BMW-POWER »
this afternoon finally fitted the 323 bilstein front legs,
forgot to take pics from the works...
brakes are still 320/6, havent got the 323i calipers together.
made a test drive, the car drives very much better, more steady to the road, though much more nervous steering and corner behave,
lowering isnt good viewable, probably because of the little wheels :hammer
now mounted is the well known new Bilstein B6 sport shock set in combination with the -35mm H&R new spring set
E10 2002tii 73'
BMW-POWER
Post by BMW-POWER »
the car got a complete polish job, this is the final result
E10 2002tii 73'
Looks nice! If you would place some new chrome trims at your windows at the front and back it would make it even better.
BMW-POWER
Post by BMW-POWER »
Peter V. wrote:Looks nice! If you would place some new chrome trims at your windows at the front and back it would make it even better.
i know, soon i'll order some parts for my 2002tii, then i'll order some new chromé strips for this car :D
E10 2002tii 73'
BMW-POWER
Post by BMW-POWER »
friday i got married!!!! the weather was beautiful, we really had a wonderful day :thumbsup
here some pics', arriving at my girl's place
signing all the documents,
our wedding-rings
some pics from the photoshoot
E10 2002tii 73'
Congratulations. Nice pictures!!!!
murran
Post by murran »
congratulations dude!
are you allowed to just have a hydraulic handbrake in belguim? in the uk you need a mechanical hand brake to pass an mot. tho you can have a hydraulic system too if you want, but its not tested as part of the mot, aslong as the system is safe and not leaking fluid etc.
useful hydro thread with fitting/bleeding guide, pictures and common questions......
http://www.trampdrift.co.uk/Forum/TD/sh ... =handbrake
BMW-POWER
Post by BMW-POWER »
some pics from a local sharknosemeeting, and short tour, been driving together with some friends, 2002 turbo, 2002tii, 2000 touring, 635csi and a e28 520i
E10 2002tii 73'
