Jan`s e21.
drshiwas
Re: Jan`s e21.
Post by drshiwas »
Hey, nice car you have there!
i have few questions about it:
1. what kind of upgrade you did to the chassis (coil, springs, shock absorbers ets...)
2 maybe you are selling carburetors? if i see right weber DCOE?
3 rear diff is LSD? original from E21 or later? for example E30 e36?
4 where did you brought s14 engine? how long you searched for it?
5. what kind of parts you used for rear coils and front?
Jannorway
Re: Jan`s e21.
Post by Jannorway »
drshiwas wrote:Hey, nice car you have there!
Hello. I Think most already is written in this tread,but I can try to answer..:)
1. I have eibach springs and bilstein shocks. Harder bushings in the rear axle,soon the be at the front also. Have ordered swaybar kit from VAC-motorsport that soon arrives.
2.I have weber 45's yes,but I will keep them for now.
3. The rear diff is 25% LSD yes,and it is original e21. Dont think if will fit from e30 on e21
4. I bought just an our from where I live,it was advertised and I just had to buy it.
5. Everything came from ground control,they have a kit with almost all you need.
1981 316 - E21
http://www.bmwe21.net/forum/viewtopic.php?f=7&t=12776
http://www.bimmers.no/forum/viewtopic.php?f=11&t=103533
2003 530 DAT - E39
2010 320 D - E92
J.K.jr.bad.
My E21(s): BMW 315, BMW 323
Re: Jan`s e21.
Post by J.K.jr.bad. »
LSD element fits from e30/e36 small diff. :wink:
J.K.jr.bad.
Jannorway
Re: Jan`s e21.
Post by Jannorway »
J.K.jr.bad. wrote:LSD element fits from e30/e36 small diff. :wink:
Are u sure? If so,it will be a little easier to get one...:)
1981 316 - E21
2003 530 DAT - E39
2010 320 D - E92
Jannorway
Re: Jan`s e21.
Post by Jannorway »
Some pics of my car..:
Loaded up ready for the race track::
Home again, new washed and happy..:)
1981 316 - E21
2003 530 DAT - E39
2010 320 D - E92
Re: Jan`s e21.
Nice report!
Jannorway
Re: Jan`s e21.
Post by Jannorway »
I´m not doing much with this car now, just driving it and having fun! It works great! However I plan some work this winter. Have to change the rear shocks as I got the wrong ones. Should have bilstein sport and got bilstein hd..:( I will always consider to change the bearings in the engine as I dont know how many km it has run and it is recommended to change them around 100000 km.
1981 316 - E21
2003 530 DAT - E39
2010 320 D - E92
Jannorway
Re: Jan`s e21.
Post by Jannorway »
Movie, auto x:
At the Norwegian track "Rudskogen"..:
1981 316 - E21
2003 530 DAT - E39
2010 320 D - E92
costask2
My E21(s): ´82 315 powered by s14
Re: Jan`s e21.
Post by costask2 »
Hej Jan,
really nice car´and keep up with the good work..
I´ve installed an s14 engine in mine also and I wanted to ask you how well you car is going with the Airfilter you have? as I saw in som pictures you didn´t install the standard filterbox.
I´m running mine with the standard filter box but the air inlet is to close to the front frame and I have the feeling that its not getting the air as it should so I´m thinking to install the open air filter as your´s..
//Kostas
-----BMW don´t follow the technology, BMW leads it-----
BMW e21 S14
BMW e46 325ti
BMW e38 740iL
Jannorway
Re: Jan`s e21.
Post by Jannorway »
Hi!
It runs ok I think,havent many other I can compare to... I´m thinking of make a shield around the filter to prevent it from taking hot air from the engine bay. I didn't use the original airfilterbox because it hit the front frame,i believe it will not get enough air that way.
1981 316 - E21
2003 530 DAT - E39
2010 320 D - E92
pic
Re: Jan`s e21.
Post by pic »
Pretty nice car! :thumbsup
