6 speed tranny
BMW 315 550hp "black smoke"
american 320i
Re: BMW 315 550hp "black smoke"
you guys wanna see a turbo diesel setup from the states?? this is a triple turbo dodge cummins truck thats daily driven and has 1200hp. 1450 lb-ft torque.
http://www.dieselpowermag.com/tech/dodg ... to_02.html
Here is one fast Dura from Finland http://www.youtube.com/watch?v=tkl6v5Cd ... re=relatedamerican 320i wrote:you guys wanna see a turbo diesel setup from the states?? this is a triple turbo dodge cummins truck thats daily driven and has 1200hp. 1450 lb-ft torque.
And only two turbos
And back to topics car,
I test fit welded parts and they fit perfect. Thinking paint all black (structur) paint.
Bmw e21 2.5 20v
Bmw 325ix touring
Bmw 325ix touring
Have to cut whole kardan tunnell of, that Mersedes tranny dont fit there.
Corners inside is good shape, so little rust.
New Davies water pump arrived also.
Bmw e21 2.5 20v
Bmw 325ix touring
Bmw 325ix touring
full of win
Little space the valves
Firs have to do tool that keep piston staight.
Next sharp edges smooth and new coatings .
And some Concrete on the block.
Bmw e21 2.5 20v
Bmw 325ix touring
Bmw 325ix touring
jeemu wrote:Little space the valves
Concrete?
Yesac/dennis wrote:jeemu wrote:Little space the valves
Concrete?
Bmw e21 2.5 20v
Bmw 325ix touring
Bmw 325ix touring
S_Kaulaote
- E21 starter
Some serious building..
Hi,jeemu wrote:Yesac/dennis wrote:jeemu wrote:Little space the valves
Concrete?
Why do you put concrete in the block?
Not install Wilwoods this summer, so is there some good calipers that fit those 323i strut and e12 hub?
Maybe around 280-300mm disk.
Bmw e21 2.5 20v
Bmw 325ix touring
Bmw 325ix touring
Almost bolt on 4 piston caliper and 280x25 diskjeemu wrote:Not install Wilwoods this summer, so is there some good calipers that fit those 323i strut and e12 hub?
Bmw e21 2.5 20v
Bmw 325ix touring
Bmw 325ix touring
so back to the concrete..... it just guna crack up (as the block expands and contracts with heat. not to mention viabrations thru the block esp. in a diesel) and come loose?. bits of concrete swimming round in the coolant. does that make the water pump run better?
Its not the same type of concrete you use for house foundations Murranmurran wrote:so back to the concrete..... it just guna crack up (as the block expands and contracts with heat. not to mention viabrations thru the block esp. in a diesel) and come loose?. bits of concrete swimming round in the coolant. does that make the water pump run better?
I believe its special stuff for engine blocks - its a tried and tested way of adding strength to the block. Another way is passing a rod that bolts each external face of the block together to stop it expanding too much. (Much like they use on old houses where the walls have bowed out) if that makes sense.
