Eddie's E21 316
Eddie.
My E21(s): [O==[][]==O]
Re: Eddie's E21 316
Post by Eddie. »
Found more rust this evening.
On the join of the inner wing and the wheelarch.
It could be worse, fortunately, it's generally pretty localized rust when I do find it.
Also tried to take the damper off but the hub assembly wouldn't come away from the control arm ball joint.
How would I get this off? A long ball joint splitter?
Re: Eddie's E21 316
They tend to get really stuck. And since you won't be able to use that one anyhow I'd go for more firepower with a balljoint fork like this one:
it may help to give it a lot of WD40 or alike the night before, helps dissolve the rust inside.
Eddie.
Re: Eddie's E21 316
Post by Eddie. »
Any reason I won't be able to use that one again?
If it needs replacing, doesn't that mean I'll need a new control arm (they're all one piece aren't they???)
Re: Eddie's E21 316
Because you completely ruined the thread on it? Get a new one and you'll have fresh bushes as well which means much less chance of the dreaded front suspension shimmy. They're not that expensive but you can always fit a used example if you want.
Re: Eddie's E21 316
Indeed use a splitter and some heat with a flame or paintstripper.
I used to untight the nut a bit, spray lotts of penetrating fluid (WD40) and then heat it up. with a fair amount of hammer hitting the nut will be getting loose.
Eddie.
Re: Eddie's E21 316
Post by Eddie. »
Got the car back on all fours yesterday.
Arches cleared of underseal now:
Also got a shot of the car without a front bumper. Quick PS of it with the holes on the lower panel smoothed off:
Eddie.
Re: Eddie's E21 316
Post by Eddie. »
Bought these the other day:
They were cheap, so pretty happy.
They need a full refurb though, but all in good time :)
m3gaz
My E21(s): looking
Re: Eddie's E21 316
Post by m3gaz »
I just love that front valance on the early cars.Its much more subtle than the later type.
Nice Eddie,i like it. :thumbsup
Eddie.
Re: Eddie's E21 316
Post by Eddie. »
Some parts arrived this weekend :)
New front wings, and repair panels for the lower rear quarter.
(piss poor iPhone camera)
Yet again, this whole 'E21 thing' has come up with a pleasant surprise.
I ordered the parts from Wallothnesch. Along with the wings came their brochure, which is potentially one of the handiest things I've had yet for this car:
Parts diagrams for the entire car. Everything is listed, and at the back it's all priced up.
Tremendous :)
Re: Eddie's E21 316
Their parts catalog can come in handy indeed, even though its based on the oem parts manual you can also find online on www.realoem.com or www.bmwfans.info
Eddie.
Re: Eddie's E21 316
Post by Eddie. »
Yep, while I know the diagrams are widely available elsewhere, I sometimes find getting accurate prices can be tricky.
Their catalogue has a full price list at the back, so it makes life easier in that sense.
I like organisation I guess!
Re: Eddie's E21 316
Eddie. wrote:Yep, while I know the diagrams are widely available elsewhere, I sometimes find getting accurate prices can be tricky.
Make sure that you refresh the pricelist sometimes because that can change from time to time. Just download from their site.
Eddie.
Re: Eddie's E21 316
Post by Eddie. »
Tonight saw the start of the final push to have the car ready for Saturday.
Windows removed, rubbers, seals and trims all removed. Sunroof and door hardware has also all be taken off the car.
Also, the all important areas are free of any corrosion.
Lower windscreen corner:
The rear windows are also completely fine.
Next few evenings will be busy ones, but it's all very exciting now :)
Re: Eddie's E21 316
Amazing, no bad surprises. Great news! Good luck preparing for the weekend!
Eddie.
Re: Eddie's E21 316
Post by Eddie. »
So the brownmobile went to the paintshop this morning.
My mate and his dad trailered it there for me :)
Very excited now :)
