My E21 M30B35 project
E21meister
Post by E21meister »
WHEEL PORN!
You can't possibly put those on a car, sling the flatscreen and mount those bad boys on your living room wall! 8)
Rav320uk
Re: My RS's nearly ready
Post by Rav320uk »
lemonayd wrote: WOW!!!!!!!!! they look the nuts mate want a set for mine how much do they stand you in mate?
So far just over £1800.
Pho21_girl wrote: Lokking verrrry good :D
Thanks :wink:
E21meister wrote: WHEEL PORN!
LOL, they are in the living room atm :lol:
Rav320uk
Rav's M30b35 Build
Post by Rav320uk »
Thought I would post up one here, as I ahven't for a while.
But basically, it goes, i'm doing an M30b35 build, so thought I would share it,as it will be the same for the E21 later.
Head off, rocker shafts removed, rockers and cam out too.
Head now booked in for Monday for a pressure test and a 1/2mm skim :twisted:
I'll take out the valves on Monday for those eagled eye fookers!
Pistons look to be OK, and the bores look good too, can still see the honing marks on them.
Looks to have been running rick though.
Going "Supercharged" on this engine, so the 1/2mm skim was put on hild for a clean face instead.
Going for a Rotrex C30 range.
Gave the head in on Monday for a pressure test and skim.
Pressure test was good, and a skim of 4 thou wasa only needed.
Picked it up this morning, removed the valves, and the guides and gave it a quick clean.
Lovely brand new Light billet flywheel, takes the E34 clutch. winkeye
Looked into the bottom end shells and big end bearings
Not good, slighty worn and will need to be replaced, so ordered they were.
Cleaned up the face with wet'n'dry and taped up.
Removed the shells and crank and pistons
And left it at that.
Tomorrow, it's clean up time, and painting the block.
Adaptors for the ITB's :D
Anyway, can't try them, as i've sent the head away for the valves and valve seats to have 3 angles put on to them, couldn't resist it as I had a very good price quoted to have it done.
Had the block honed today too, needed doing as there was slight scoring on a few of the bores.
Had a load of parts Soda and media blasted to get rid of all the oil and wax on the parts.
The ITB's were like this
To this
Also, had some head work done in the last few weeks too, thought it would be nice to treat it to a better flow
Had the seats and vlaves cut to 3 angled finishes.
Next new seats, cutter pilot installed.
The first cut at 60* is the bottom cut.
Followed by a 30* top cut, then the seat cut, both are on a double sided cutter. The seat cut is at 46* the two faces will bed in together within the first moments of the engine being started.
This is what you end up with after it has been soda blasted, and all the cuts finished.
A before and after, not alot of difference really as the head had already been scrubbed, but the soda gives it a nice uniform look and doesn't damage the surface of the alloy.
Firstly, all new chain guides fitted yesterday,
New thrust bearing and shells fitted, dropped the crank in and tightened up the bolts.
For some reason, there was quite alot of end float which was a bit baffling, as everything was measured by using a micrometer :? .
So off came the crank again, the old thrust bearing installed, and then everything reinstalled again, this was to check the origional end float on the crank, cam to 0.005th :?
So, vice versa, new one installed, and for some reason, don't ask, there was reduced crank end float to about 0.002th, so checked and rechecked, phoned a few guys on the Zone to make sure and all is now ok. :D
Thought i'd strip/paint and rebuild the ITB's ready for when they're needed.
And a few more,
That'll be it till next week when I get the head back.
Then i'll try the Stainless Steel 6 branch and see what needs to be done to make it fit.
And this is where it satnds atm.
Hopefully more later on this month.
Re: Rav's M30b35 Build
Nice. I know people bang on about m30 being heavy but the epic turque is great. I want a hot 3.5 in my e12.
Rav320uk
Post by Rav320uk »
Don't suppose you took any pics of the headwork done on the TWR engine Mark?
lemonayd
Post by lemonayd »
welcome back Rav , glad to see you havnt given up on the E21 . great pics that engine's gonna be epic.........
...ayds
www.pristinebodyworks.co.uk
Re: My E21 M30B35 project
Welcome back! I merged your topics to get the project together in one topic, please update here!
Amazing work and that's going to be one hot M30 indeed! Using S38 ITB's?
Keep up the good work and keep us updated!
Rav320uk
Post by Rav320uk »
Thanks, i'd actually forgotton I had this thread going. :shock
jimbob
Post by jimbob »
Good work keep us updated as the engine goes back together
I love to see an engine rebuild.now rebuilding my old m20 never
Done it before but its great fun.those throttle bodies look great.
E36 328i Daily driver
E36 328i Touring
Rav320uk
Post by Rav320uk »
Will do lads. :launch
thats a very nice job your doing on that engine.
Rav320uk
Post by Rav320uk »
Cheers Nas. :smoke
:) no worries. I have to respect you for sticking with your m30's mate.
So just out of interest I was wondering what sort of power are we talking from all this engine stuff your doing?
What you going to be doing for brakes / suspension etc
dannyboy
Post by dannyboy »
:thumbsup
e21 335i gone but not to far.
e21 316.. still
ford puma..(wifes honestly)
Rav320uk
Post by Rav320uk »
Thanks Lads.
Nas, you know i'm M30 through and thorugh :driving
Power wise, with out a Cam change, i think about 230hp, with a cam change, i think close to 250bhp.
I'll need to bed the engine in after it's installed, and then Supercharge it, then it should be about 450+bhp :launch :launch :launch :launch :launch
