Auxiliary gauges
Post by ac/dennis »
Oops,sorry :lol:
--ALPINA--
Post by --ALPINA-- »
I found this in my archive....
J
Rav320uk
Post by Rav320uk »
Thats a nice custom job.
I've saved the pic btw, hope you don't mind. :P
E21meister
Post by E21meister »
+1.
And reversed it... :D
--ALPINA--
Rav320uk wrote:Thats a nice custom job.
I do mind mate, actually delete it now!!! :lol: :lol: :lol:
J
--ALPINA--
OK mark, i was looking thru my archive again and i knew i had some info for ya.. so hope this works.. it shows VDO but its the same shit..
http://homepage.ntlworld.com/john.combes2/Vdo.htm
J
Cheers mate
Sierpien
Post by Sierpien »
I like my setup :) :
Alex von Falkenhausen
tommi_e21
Post by tommi_e21 »
im gonna buy a block of wood tonight n get carving for my mould for my carbon fibre dash pod i think :). or maybe some modeling foam or sumin, that could work, that will gimme sumin to do when im cold.
that and buy some resin for the carbon fibre.
doubt halfords do release tape though
petroscf
My E21(s): '77 EU 316 manual
Post by petroscf »
Ok, if I understood well, the senders are some kind of wires, aren't they?
In case of gauge-pods fitted on top of the dash (as it's the case with most E21s), where do the wires pass from (inside the dash) to reach the engine bay? is it needed to pass them from the ventilation ducts that are exactly behind the pod (then the wires would be visible, which I wouldn't like at all) or can one pass them inside the factory speaker hole, under the pod?
/oo=00=oo\
E21 Forever
Now I finally have all the senders and adaptor (they sent the wrong one hence the delay) I'll try and get on with doing a step-by-step guide for those people who are as clueless as I am when it comes to this stuff.
im going to place mine in the same place Sierpien has! its nice n tidy that.
Baron Von Franzen
Re:
Post by Baron Von Franzen »
--ALPINA-- wrote:Hi mark as said, my current stup in my car is below, hope this gives you an idea!! if anything ill guide you thru wiring if your not sure mate!! The oil Temp isnt connected, will be when i fit a mocal oil cooler..
J
Hi there from Bimmerforums/Australia, sorry to resurrect an aged thread but I just bought this very same tri gauge cluster and I was wondering where you would get matching vdo gauges to fit the size of the gauge holes. I'm after Oil pressure, oil temp and I'll have a wideband O2 sensor in there too.
Thanks heaps guys.
Hal
Re: Auxiliary gauges
The gauges from an Audi coupe, or similar, will fit fine.
Baron Von Franzen
Thanks for the reply brother, which ones are in "Alpina's" picture? I actually wouldn't mind those exact ones.
