Another 320/6 to 325i conversion
Re: Oh No! Another 325 Conversion
That'll clean up nicely. A bit of crackle black on the rocker cover and clean up the inlet manifold maybe?
DrGonzoPOW
Post by DrGonzoPOW »
Yeah, im gonna give it a reet nice clean up and a lick of paint. Dont know about that crackle stuff tho, reminds me of the jap tuning scene. Gonna give the engine bay a going over too with some fresh paint, although it'll just have to be the best match i can get as BMW dont do my colour anymore :(
Got this sunday off so im thinking about making a start on things. I was gonna wait till summer but it would be nicer actually having the car done so i can get the most out of the weather (If and when it arrives)
Engines just on a pallet at the mo, is it ok just sitting on the sump ?
Wakefield Hellfire
DrGonzoPOW
Where do you run the wire for the battery to boot conversion ? Does it need a hole in the firewall then running under the drivers seat and into the back ?
Wakefield Hellfire
Jason_323i
Post by Jason_323i »
You can take it the throught he car and get a hole in each bulk head or take it under the car and just a hole in the boot floor.
Jason
Z3M Coupe
2.8 Z3 Coupe
Caterham Supersport
rob0r
Post by rob0r »
I cut absolutely nothing installing a battery cable in my E21. Force it through the grommet next to the scuttle where all the wiring goes into the car, run it along the inside sill, under the seat frame work, up and into the boot where the rear seatbelt reels are bolted down. My cable was from an E36. I take photos of the most mundane things...
Mine goes thru the same as Robs too.
rob0r
Post by rob0r »
It's not that I'm adverse to cutting, I'm all for it! I have to hole saw my bulkhead for the M50 ECU loom soon...
DrGonzoPOW
That looks good. Ive got the battery wire but think i need that little junction box with the red pos sign on it. What did you attach it to in the boot for the grounding ?
Wakefield Hellfire
Mine just bolts to the body on the panel behind the seat back iirc.
rob0r
Post by rob0r »
Mine is bolted by a top mount nut.
drjim
Post by drjim »
I used cable off ebay, a battery terminal I already had, and also from my pile of collected bits a little black junction box with two 10mm studs in which I have screwed on where the ignition amplifier thing used to be. Cable runs the same way as the others. I have stuck some spare fuel hose and the outer rubber sleeve off the MIG torch I recently took off my welder for an upgrade. The hose and torch sleeve are protecting it from any potential chafing where it comes through the rear bulkhead, under the seats or under the carpet - figured there was no harm in it.
1982 Saphirblau Baur 325i
Cars all gone!
DrGonzoPOW
Does anyone have a spare black junction box thing ? Rekon im gonna do the battery Sunday and start taking things to bits.
Wakefield Hellfire
drjim
Post by drjim »
I got mine off ebay, I'll see if I can locate a link for another later on
Jim
Cars all gone!
murran
Post by murran »
engines fine sat on the sump. i changed the ally e30 sump on mine for the e21 tin sump.
i chopped up an old set of jump leads and bought some big ring terminals from halfrauds.
reguarding the oil cooler, id bin it personally. its not needed and just complicates things. mines not got one anyway....
DrGonzoPOW
Does it just need blanking off with some bolts or summert ?
Lemme know if you can about that junction thing please Jim, i need to get started!! Ta
Wakefield Hellfire
