BMW 323i M50 2.5
tommi_e21
Post by tommi_e21 »
hmmmmmm i didnt realise they where different sizes, bugga. ok i will have another little fink
rob0r
Post by rob0r »
The current state of play, it's getting there
I've done some odd bits and pieces this week, including cutting the inner wing and refitting the fuel tanks and replacing the breather pipes (something I don't want to do again!). I've started on the wiring and putting the battery in the boot. I also replaced the waterpump, thermostat and thermostat housing. Should be running soon.
Excellent solving of the clearance issue! :lol:
Good work my man!
Jason_323i
Post by Jason_323i »
Rob
Was the V8 inlet any good
Jason
Z3M Coupe
2.8 Z3 Coupe
Caterham Supersport
rob0r
Post by rob0r »
Hi Jason,
Thanks again for sending it. Unfortunately it was too wide between the throttle and inner wing, and I would of had to use big reducer rings to fit the M50 TB. You never know I might end up using it for something else so I'm going to paypal you.
In the end this was the quickest and cheapest option I had, when it comes to put it back on the road I'll seal it all up.
Cheers
tommi_e21
Post by tommi_e21 »
samco would o been cheaper, make sure you use some thick steel when plating it back up, does the wheel rub on full lock left?
rob0r
Post by rob0r »
Since it cost me one slitting disc so far I think this will work out cheapest. The samco would have to be a very tight angle and different diameters at both ends, it would also have to extend quite far forwards to create clearance for the MAF and wiring past the inner wing. It's no where near the wheel on full lock and won't protrude any further towards the wheel than the brace that's already there. Also E36 elbows are off the shelf.
tommi_e21
Post by tommi_e21 »
cool cool, to be fair knowing me, i would of done the same if i had a welder,
Rob one night can i bring my e21 to you to get the Diff welded, will bring a couple o beers and some munchies, dont really wanna pay the goon next door to borrow his welder again, would rather spend the fuel money coming over yours n making a night of it.
rob0r
Post by rob0r »
I normally borrow my friends welding rig to get some serious power into it but he's on the farm also (with the E12), yeah it should be fun. When are you thinking of?
Empty the oil out of it and give it a good clean (I normally pressure wash mine) before you come and it make things much easier.
tommi_e21
Post by tommi_e21 »
i was gonna weld it in place on the car :), i not gonna have a boot floor so will be easy to access, and wont be till after crimbo i expect, cant afford the fuel to come over before then
Don't suppose your coming to Ace on Monday Rob?
E21meister
Post by E21meister »
austin25uk wrote:dont really wanna pay the goon next door to borrow his welder again
Aww, I like your next door goons, they're even funnier when they've had some additives... :wink:
rob0r
Post by rob0r »
It really would be much easier to do it off the car.
Fraid not RB, I'm working from home at the moment so I don't go anywhere near London so it's not an option.
nige21
Post by nige21 »
Your brave! I was thinking i would weld an ally bend directly to the TB housing but im not sure its possible to weld to the diecast. Might go the silicone hose method.
Going to have air filter under the wing or in the bay?
E21 323i M50 (now s50b30)
E30 318is
MK1 Escort Cossie (sold)
murran
Post by murran »
loving the "if it dont fit, make it fit"! :lol:
