Project 326i
Re: Project 326i
what paint did you use on the underside?
Re: Project 326i
I used Body Epoxy Primer, and something wheelspray as color.
ll323i
- E21 starter
- My E21(s): 1982 323i
Re: Project 326i
Hey Pic!
I've just skimmed through your topic (i did it several times on the hungarian forums), you've done a monumental job.I hope we could meet soon
niske
- My E21(s): '82 320/6 A
Re: Project 326i
Can you tell me please how standard 323i k-jetronic submits high revs with increased displacement of engine? Is there any lack of fuel?
I want to make K-Jet 2.6-2.7 M20 but with 325 head(885), 325 manifold, pistons etc.
What do you (or anybody else with that practice) think, what is the better choice? Just in case of intake mixture flow?
- Mihajlo
- My E21(s): 1982 315swap323i
Re: Project 326i
K-jet is mechanical fuel injection and can be "opened".
If you really manage to lack with fuel, go for 911 K-jet (or better, switch to motronic or some standalone)
Mine K-jet was in good condition (not perfect) and I really didn't like fuel consumption. Than I switched to L-jet from 323i E30 and all I can say is it was good upgrade.
sad tek vidim odakle si
javi se na privatnu poruku
Re: Project 326i
With Alpina achieving 170 BHP from the stock fuell dizzy in the C1 I think it can do a bit more, 170-180-ish. If you want to go further using K-Jet you can use the larger Porsche 930 series dizzy as indicated by Mihajlo, that has been done more often on stronger 2.7 conversions for example by Hartge. That should easily get it to 215-220 BHP.
- croma_man
- My E21(s): '83 EU 327i
Re: Project 326i
My opinion, go for the motronic or standalone, yes its a timely and costly effort, but you'll have the power the engine can produce...
Re: Project 326i
Yes and no haha. Motronic or standalone will most likely work best, provide to be reliable and is likely to give a higher output. But if you'd like to retain original looks, it is good to know there are options for that!
- niall
Re: Project 326i
my old 327i was k jet adn it was quicker that a 325i e30.
all of these fuel systems have headroom, the mixture on a k jet will not go wrong with more displacement because it will just read more air flow air a lower load/rpm than before. i think 180-190hp could be achieved with an unmodified k jet
E21 RB20DET
E46M3
E34 52???
Ford Sierra v8
Range Rover v8
300zx Twin Turbo
Audi A4 daily
E21 RB20DET
E46M3
E34 52???
Ford Sierra v8
Range Rover v8
300zx Twin Turbo
Audi A4 daily
Re: Project 326i
Don't forget the Schnitzer turbo used K-Jet as well, that made 200bhp
From memory the injector can supply fuel for about 50bhp per injector. Or 300bhp for six.
I would guess the main limitations of K-Jet for much over 200bhp are the air flow restrictions through the metering unit and filter box.
Ben
Ben
Re: Project 326i
Wow, what a party has been here.
I love the k-jet. Why? It's a simple system with one of the best throttle response. Niall and Duracell was right, but mention one more reference: the Callaway 323i turbo with 280 horses, and yes, with k-jet, with an additional injector. (I think they used the cold start injector on higher revs) Someone loves the electronic engine management, someone (like me) not. If your injectors good, go for it, you will not regret it.
If
Re: Project 326i
Finished the exhaust yesterday and made some music.
Re: Project 326i
Little update. Repainted the front of the car on the end of april, and we take a long trip.
On the funny ferry on th river Tisza with my wife and my little childs.
