Kam its a 32/34 dtml manual choke.kam09 wrote:Looking Good!!
Wondering what weber carb you put on? Sorry very new to things![]()
kam
316 - m52b28 / individual+
yeah i got the coilovers on the front fitted on bank holiday monday., I had to turn up the stiffness on the rears as they were much softer than the fronts and pretty bouncy - i did about 4 turns and this seems to have leveled out the stiffness.
Had to modify them to work with the willwoods. much quicker the second time around!
did it all on my drive meself. heres a shit picture as proof lol
Also i got my rustbullet and paint brush out. and gave this shit a lick of paint - instead of hammerite blue (L0L) i have decided that my suspension parts will be shit silver lol. that rust bullet stuff comes in any colour as long as its silver.
The Gaz coilovers are gonna stay matt black though.
i fitted my polybushes on the rear arms - i used the old threaded bar / sockets, washers and nuts method. it might not look like much but it was a bit of a pain
i fitted the painted front 23mm anti roll bar and the ARB polybushes and took it for a spin last night, and i have actually SOLVED the stupid 50mph shimmy "handshake" steering you get on these cars.
Its bloody brilliant to drive. Im going to be fitting the rear axle on sunday at my mates dads' garage in Sheffield (as in proper business type of garage lol) so ill have all the tools necessary.
323i Handbrake cables ordered from the dealers and arrived today £50 for the pair that cost me! its rediculous eh.
Anyway ill have more pics on monday i guess.
- e21-Mark
- E21 Master
- e21-Mark
- E21 Master
cheers mark. hardest bit is nearly over, i think the engine change will be much easier than replacing all the bushes and shit.
i was thinking bout that wonder bar while i was under the car last night. i reckon i will do it when the engine comes out.
edit - that bar does look pretty simple to make actually. i think i even have some bar laying around that will do the job nicely.
- e21-Mark
- E21 Master
i was very nearly going to buy those. i changed my mind as i thought that they wouldnt be able to give me enough adjustment to dial out all the camber. i also had a feeling that these would be a complete pain in the ass to adjust - hense the camber plates.
I also hear that these eccentric types of bushes like to move and then your camber settings are screwed. you might wanna chat to RPM and get thier opinion. there is a chance i might be talking shit lol.
the pic of the bush above is the normal rear arm TCA polybush.
- e21-Mark
- E21 Master
- e21-Mark
- E21 Master
if i was doing it then id go with nas's plates. the eccentric bushes look shit.
im not guna bother doing it. as even with the camber plates it doesnt solve the the problem of the cv joints not being at 90 degrees to the drive shafts with a lowered car. in my case this means broken cv joints while drifting.
i have broken 3 joints while it was on the old chopped lowering springs to prove it!
hasnt broken any with the spax suspention on it, as the rear ride height is quite high.
- e21-Mark
- E21 Master
hi guys, today was a long long day, i finally did the rear beam / rear disk conversion.
you start off with shitty drums.
undo brake lines, prop, exhaust and the rear coilovers, and then undo the rear beam main bolts and then struggle like hell trying to get the rear axle main bush plates off!
you end up with this
after much blood sweat and cursing
finally on.
i adjusted the rear camber plates so that it was on the maximum positive settings and the toe I put to 1 degrees.
the rear wheels sit with visibly MUCH less camber, theres still some negative camber i havent measured it yet, but i will take it to get the 4 wheel lazer alignment done.
When your on the motorway if you went about 90mph the car felt edgy and all over the road and pretty scary at high speeds.
Now the car is totally planted even at high speeds, and even more awesome when your going round bends! seriously cant tell you how much of a positive this has made to the way the car drives.
the rear anti roll bar has pretty much eliminated rear body roll.
some people had problems when fitting the wilwoods and having big pedal travel, i thought that i would have had the same problem after putting rear disks on but in fact the brakes are better than ever and theres no extra brake travel.
It doesnt look like ive done much but tbh its a pretty long winded and difficult job replacing a rear beam that hasnt been took off before! defo glad i didnt have to do this on the drive.
suspension and brakes finally done!!!
i can start on getting the engine out of the 525 wagon, ready for the engine swap.
Gonna enjoy the m10 engine and modern handling for a little while longer first - and have a month off doing any major jobs.
finally on.
