Identifying LSD limited slip differential
Posted: Tue Dec 18, 2012 11:14 pm
by cobbler2u
Hi
Can anyone confirm the numbers on an lsd.
Been oferd one with these numbers on
33:1 / 1204 898 / 2.2 2.25.
Cheers
Mod: topic title edited, this one might go into the top tech topics or FAQ section.
Re: lsd id
Posted: Tue Dec 18, 2012 11:41 pm
Re: Identifying LSD limited slip differential
Posted: Wed Dec 19, 2012 6:31 pm
by Wondermike
I did find a tiny S next to the back plate that gave it away.
The rest of the diff was so rusty that i didn't find any other clues on it.
Posted: Fri May 03, 2013 9:51 pm
by Lars-Nord
Now it has happened thing with my car. I had it jacked up to replace hardy disc. When the exhaust system was in place, it's a little tricky to get in place. Alpina made slightly larger exhaust system and it`s going over the right shaft. It's a bit cramped and I have to spin a little on the mid shaft to check for subs. Then began both wheels to spin the same direction. A little surprised, I put the car in gear and started it. The wheels spun in the same direction. I tried also to hold back one wheel, but it was not possible. So now it looks as if the differential has gone from open to LSD.
Can it be so that LSD has not worked, because the car has been too much still? When I bought the car, then spun the wheels opposite directions???
Posted: Fri May 03, 2013 10:11 pm
by Wondermike
Open the rest cover and you know for sure.
Posted: Fri May 03, 2013 10:20 pm
by Lars-Nord
I will try that next week and put on the Alpina cover.
Or not.... Have to make another bracket. Shit.
Posted: Tue May 07, 2013 11:09 pm
by Lars-Nord
This is also a way to find out.
