rear poly bushes
mcjjordan
My E21(s): Uk 1980 316 m52
rear poly bushes
Post by mcjjordan »
as title suggests
am in need of some rear beam bushes
ive done the fronts in poly last summer .
but where can i get the rears?
gonna drop the rear out in the spring and check all is good as am getting a knocking from rear occasionally
then maybe il get sourcing parts for the m52 conversion i want
also am in need of a LSD if anyone selling one :wink:
Re: rear poly bushes
We have this lovely thread called Where to get E21 parts - the bmwe21.net directory that suggests for example http://eurometric.com and http://www.strongflex.eu/en/
LeeLee
My E21(s): E21 316 1981
Post by LeeLee »
I got them from ebay.
big and yellow they are,
think they came from Poland possibly,
can't remember now,but they work great,just hit them in the cup with a mallet one side in first is the trick I used,easy to change though just jacked up ether side,undone the two bolts on the sill
then the large bolt that retains the bush,
then two bolts ether side behind the bush.
the two behind the bush keep the bush case to the beam so you can remove without dropping the whole beam,had exactly the same thing haha so much better now
Sounds like an easy 'on the street' job like that!
LeeLee
Post by LeeLee »
Well maybe it isn't a on the street job but was very surprised by how long it took once started
AndyBaur
My E21(s): 1983 320/6 Baur 5-speed (now gone)
Post by AndyBaur »
BMW do Sport versions:
33 33 1 118 568 (left)
33 33 1 118 928 (right)
They seem nice & firm without being over-harsh. Do you really need polybushes?
They're an easy swap unless the small socket bolts (M8 x 22) on the sill seize & you have to drill the head off. You can get new brackets -33 32 1 115 960 (left) & 33 32 1 115 961 (right) if the threads are damaged.
AndyS
LeeLee
Post by LeeLee »
The poly ones wasn't that expensive and feel nice I think
yatisr
Post by yatisr »
I have a set of Eurometric bushes but have not installed them for fear that they are too hard for daily use, especially on the less than perfect roads in Malaysia. Are there any views on whether these Eurometric bushes are suitable for daily use if you want a balance between comfort and handling?
AndyBaur
Post by AndyBaur »
It's all down to personal preference as to whether they are too hard.
Currently, it's a fashion thing to polybush everything that has a bush in it. It's simply not necessary - if it was BMW would have done it. Ask yourself this, who spent the most in R & D, BMW or a Polish guy in a shed? Who knows most about chassis development & setup?
For racing or a track-only car then polybushes will be the way to go. For road use then you need some compliance in the suspension otherwise you just spend your time skipping from one bump to the next. Yes, the car will feel really 'tight' but is it actually adding any more control? Not when you're airbourne!
In some cases (E36/E46/Z4 trailing arm bushes) polybushes are extremely detrimental as they bind up, locking suspension movement with obvious consequences.
The rear bushes are easy to fit on an E21 (you don't even have to take the wheel off) so go ahead & try the polys. You can always switch back to oem Sports if they are too hard.
AndyS
I'd go with poly bushing everywhere up front, as it's a bit of a weird design and you want to retain the steering geometry. New OE rears should be fine for most road use though, or stiffer if you're running more power or on track.
Has anyone got an old steering rack mounting bush they can send me please? I need one to source a poly version in the UK.
AndyBaur
Post by AndyBaur »
Are you talking about these from Eurometric?
£27 doesn't seem bad - not sure of postage costs.
AndyS
AndyBaur wrote:Are you talking about these from Eurometric?
By the time they arrived they were just under £100! They send them in a bloody great box for some reason, so postage and customs charges bumped the cost right up. It might be worth trying a group buy and a US owner, to post for us, but a UK supplier would be better.
LeeLee
Post by LeeLee »
I got poly bushes for 45 quid ;)
Which? Steering rack mounting bushes? If so, where from?
LeeLee
Post by LeeLee »
Sorry thought peoples were still talking about rear bushes,I would love steering rack bushes think il have to get some but trouble is have to decide if I want manual rack as mines p s
