Welcome to the E21 resource, the worldwide owners gallery, and get your answers, fast! ____ Scroll naar beneden voor het Nederlandse forum! https://bmwe21.net/forum/
Help me cars making crazy electrical noise --update--
Posted: Sun Feb 23, 2014 8:51 pm
by LeeLee
Just tried to start the car and it made a slow low noise from the starter,tried it again it engaged the fly wheel but sounded like it didn't properly and now it's just making a fast short electrical noise,the starter isn't that old but with problems with the car probably has bin used more than should of bin,it's a Lucas starter cars a 316 help don't know what to do
Re: Help me cars making crazy electrical noise
Posted: Sun Feb 23, 2014 9:51 pm
by trash-berd
Could be a bum solenoid not fully engaging? Could you post a video of the sound your hearing? I've had to replace a brand new starter unit within 6 months of installation before. Bum units happen.
Posted: Sun Feb 23, 2014 10:34 pm
by LeeLee
Il try and as a video in next 15 mins,that's what I think it is,really? That's not very long at all,ok il try now
Thanks
Posted: Sun Feb 23, 2014 10:50 pm
by LeeLee
added this video
Posted: Mon Feb 24, 2014 6:45 am
by trash-berd
That almost sounds like the solenoid engaging and disengaging. Maybe your flywheel teeth are shot? I have no idea on that. Might be worth having someone start it while your inspect the area.
Posted: Mon Feb 24, 2014 8:20 am
by LeeLee
I hope it ain't the flywheel
Posted: Mon Feb 24, 2014 8:28 am
by e21-Mark
Are you sure battery has a full charge? Hook up some jump leads or a booster pack.
If you can, have someone give the starter a good whack with a rubber mallet or piece of wood. Sometimes the motor can stick.
Does the engine bump start ok?
Posted: Mon Feb 24, 2014 9:06 am
by LeeLee
It's a auto,don't think I can bump start it,Im going to get some leads on when I get back,when I've had a dead battery before it hasn't made this kind of racket,but it's possible,I've had a lot of problems starting it last few months which I've sorted now,I'm sure trying to start it a lot hadn't done it very well,I replaced the battery before Xmas aswell but the first thing il check
Posted: Mon Feb 24, 2014 10:37 am
by gazzab1978
Hello lee, I have jump leads I could bring round to see if it's the battery. What time soupy Finnish work today mate?
Posted: Mon Feb 24, 2014 10:53 am
by e21-Mark
Also check the engine earth strap. A poor earth can cause all sorts of electrical gremlins.
Posted: Mon Feb 24, 2014 12:22 pm
by LeeLee
I know it's attached but it looks grubby
Posted: Mon Feb 24, 2014 12:56 pm
by LeeLee
How do I get a good earth on the engine? Could I use the insulated style earth normally used for battery earth I know they do them at halfords,or does it have to be a original style
Posted: Mon Feb 24, 2014 3:36 pm
by LeeLee
It's not the battery,just got a jump by a mate,I'm now taking the starter motor of to have a look it's tight to get to the top bolt lol had to take a water way hose off
Posted: Mon Feb 24, 2014 4:26 pm
by LeeLee
Re: Help me cars making crazy electrical noise --update--
Posted: Mon Feb 24, 2014 7:26 pm
by LeeLee
Replaced the starter and the starter doesn't fit right it's a Bosch one as they ordered me one instead of Lucas,so but it makes a loud hitting ringing noise
