In a short while we want to fit the front side panels to our E12.
When we took them of we saw some rubber filling (dried after 40 years) Now we've cleaned and painted the car, so we want to put it back on the car (a pillar + horizontal part)
and I have the following questions:
- at Realoem its called filling rubber with part nr: 41359058743, when I google it i come up with POLYURETHANE SEALANT (kit) Is this the stuff I need to use?
- if so: how much do you need to put on? do the holes where the screws go in need to be covered, or the whole a-pillar + horizontal part?
- are there more places on the car that need the same treatment?
thanks
filling rubber question
- Mihajlo
- My E21(s): 1982 315swap323i
Re: filling rubber question
search for butly rubbebr stripes
that's it
that's it
- My E21(s): Non E21: E28 525E, E12 535i
THanks! so you put the tapes over the a-pilar, over the holes and then just screw through the tape?Mihajlo wrote:search for butly rubbebr stripes
that's it
- Mihajlo
don't put that over the holes because you'll have problems screw the bolts in.
put it around bolt holes like sealant.
sounds like a good plan, thanksMihajlo wrote:don't put that over the holes because you'll have problems screw the bolts in.
