E21 K-jet to Weber help
Posted: Mon Apr 06, 2020 6:46 pm
by Jr3
I've been in the process of getting the CIS system out of my m10 e21 and replacing it with a Weber 38/38 but I'm at a crossroads. What to do about the fuel system? Does anyone on here have experience with this conversion? Any feedback or help would be greatly appreciated.
Re: E21 K-jet to Weber help
Posted: Tue Jun 09, 2020 12:00 am
by bimmerman78
I just went in the opposite direction, but have enough experience with vintage engines to be of some help.
You will need an electric fuel pump for a carbureted application, the system only requires 4-6 psi to supply the carbs.
install an in-line, low pressure filter. There are many options here, I recommend the type with a glass housing.
Removal of the in-tank and in-line pumps is required, and install a pick-up tube for the external electric pump to draw fuel out of the tank.
hope this helps.
Memo
