Lifting Up An e21
Posted: Fri May 21, 2021 4:31 pm
Hi,
Could anyone recommend the best way to get an e21 up in the air on 4 jackstands / axle stands so I can change the gearbox oil?
I've gone online to investigate but there seems to be some debate about using the jacking points due to corrosion (mine doesn't have any corrosion by the way!).
Anyway I need one or more points to lift the the car using a trolley jack and another one to put the jack stand under before I lower the car from the trolley jack. Please bear in mind that I only have a simple garage and no lift!
Thanks in advance for your help.
